Hi just a quick question I have a 316i which came from the factory without speakers in the rear shelf.
I have bought some 13cm ones as was told these were close to the OEM size, but I just wanted to know if somebody could tell me exactly where the speakers were fitted on the shelf before I go cutting the shelf to fit them. I want them to look as OEM as possible.
Factory position for rear speakers
Just buy a shelf with the cutouts already done - you can usually pick them up for about £10.
If you want it to look proper OEM its the best way
Jim320i
- E30 Zone News / COTM Team
What Rob said!
If not, have alook inside the boot and see if there are holes in the centres of where the speakers sit? I'm not sure to be honest but doesnt the metal drop down in the boot roof lining where the speaks sit? If so, poke something up and make your hole that way, then cut to what you need.
Orrrr, what Rob said... And sell yours as a 'Uncut shelf'!
suedenim
I've fitted rear speakers recently and just bought a s/h shelf, thinking that an uncut shelf is worth keeping if I ever want to go for really clean look in the future
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
suedenim
It is indeed concave but not a regular shape iirc, there may be some sort of reference, hole or something?Jim320i wrote:What Rob said!
jonny323i
if you take the shelf out there are marks for the corners of the speakers underneath
Touring for life
