Dif Swap q?
Sanchez
Post Sun Jan 01, 2012 5:26 pm
Swapped my diff from small to medium case but didnt need to adjust the prop, it all fitted like a glove.
1st diff swap ive done and just wondered if the prop will be fine?
Drove it 2meters forward and backwards as car was blocked in and all seamed fine.
rix313
Post Sun Jan 01, 2012 5:34 pm
I seem to remember people having similar experiences when I was asking about fitting my medium case diff. I had to adjust mine. As long as it's all tight and done up then everything should be fine.
Sanchez
Post Sun Jan 01, 2012 5:59 pm
I pulled the prop out and the adjuster was a fare way towards the rear of the car if you no what i mean.
When i measured the difference in small and medium cases its about 1cm in length from the mounting bolt to the prop bracket.
