Interior heaters and Central locking not working
echo30
Post Sun Jan 01, 2012 7:40 am
Happy new year to all.. iI have a Hreg 325i Sport just wondered what the colour of the relays should be that are in a bank of 3 on the ns of my enging bay. seperate relay box, what do they control? As my heater motor does not work also elec windows or central locking . Is there a main common relay for these...
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jan 01, 2012 8:38 am
Those three relays on their own are the Lambda Sensor Heater, Fuel Pump and DME relays; identifiable by looking at the wires going in underneath. They have nothing to do with your issues.
If you look at the Fuse Box:
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
You'll see that your three faults go through three fuses (17, 20 and 27), so they are in part unrelated.
For your Central Locking, look at the Red/Black wire issue:
http://www.e30zone.net/e30zonewiki/inde ... re_Problem
For the Windows, make sure the windows work with one door open. Do the switches light up? If they don't work with either the door open or the IGN switched on, then there's probably an issue with the cut-out switch located next to the gearstick.
As for your heater blower, does it work on Speed 4 only, or not at all? It's common now for the resistor pack that controls these to corrode and die, but you can replace this a lot more easily than replacing the entire fan assembly. Another option will be that the motor itself has seized, but you may be able to fix this yourself with a bit of force and some lubrication.
Finally, have a check of your electric mirrors. If they've stopped working too, then the windows, mirrors and fan blower faults will all be traced back to the unloader circuit, associated (on facelift cars) with the green/black wire to the starter motor.
Searching the Tech Forum works wonders if you get stuck.
