Fuel pump and wireing help please :-(
gafta
I'n need of some advice . I am currently helping a friend who has a e30 316 coupe . It has a carb engine with a manual fuel pump (tick tick) . We are i'n the middle of doing a engine transplant with a 318is engine from a e30 . How would I get about with the hp fuel pump ? There is no wiring under the rear seat for a fuel pump . I have looked on eBay for a external pump and have come up with a few . Are these easy to install and wire i'n ?
[/list]
A high pressure fuel pump, as used on most E30s will fit directly in place of the fuel pick up in the tank of your 316, although there is some question about picking up the last of the fuel in the tank if your's doesn't have a metal cup welded to the bottom of the tank for the base of the pump to sit in.
The last 316 I played with had the cup in the tank, and the wiring for a pump as far as the plug and socket at the RH side of the rear seat pan. Just the loom that goes down through the seat pan and to the speedo pick up, brake wear sensor, fuel level sensor and low fuel light had the pump power wires missing.
Your iS engine loom will have the power feed for the pump on a green/purple wire on pin 13 of the engine loom main (C101) plug. This should mate up with a purple/red wire going from pin 13 of the body side of the C101, which goes to fuse 11 in the fusebox. From there, a green/purple wire should go from the other side of the fuse, down through the duct under the fusebox into the area behind the glovebox, down in the corner behind the front of the speaker trim panel, all the way back the LH sill to the LH side of the rear seat pan, and across the seat pan to the 8 (?) pin plug and socket I mentioned earlier.
You will also need to add the fuel return pipe, which runs right beside the fuel feed pipe, and goes from the fuel pressure regulator on the engine to the second pipe on a two pipe E30 fuel pump.
gafta
My Moore you are a legend ! Transplant takes place tomorrow morning . Just collect the engine . Fuelling was my main issue as I have no idea what to do with pump . Thanks Brian . Will keep this post updated to let you know how I get on .Brianmoooore wrote:A high pressure fuel pump, as used on most E30s will fit directly in place of the fuel pick up in the tank of your 316, although there is some question about picking up the last of the fuel in the tank if your's doesn't have a metal cup welded to the bottom of the tank for the base of the pump to sit in.
johnl320
How old is the car, mine is an 87 and had the wiring under the seat, mine also has the c101 plug on the bulkhead, I have fitted an in tank pump to my 316 carb tank and have had no issues.
gafta
Hello , it's a E reg coupe . No wiring to be seenjohnl320 wrote:How old is the car, mine is an 87 and had the wiring under the seat, mine also has the c101 plug on the bulkhead, I have fitted an in tank pump to my 316 carb tank and have had no issues.
Should have mentioned that my 316 was one of the last ones made, on an 'F' plate
gafta
i take it these wires have nothing to do with the fuel pump Brian ?
http://i1213.photobucket.com/albums/cc4 ... cde615.png
That's the loom that goes to the fuel pump, fuel level sender, low fuel light switch, speedo sensor and brake pad wear sensor.
The plug and socket on the rear seat pan I referred to is the one under your hand, held by cable ties.
Check this connector for a green/purple wire going into the top right side (as it lies in the pic.) If this is present, then the fuel pump circuit is wire up to here. If the green/purple continues out of the other side of the plug, then I would expect to find the fuel pump plug somewhere under the pump inspection cover.
gafta
Cheers . I have located these wires , all I now need is the wiring harness . Will a 325i pump be ok for the m42 318is engine ?? If not how about the 318i fuel pump ? Is there much difference . -also dose the sender unit sit along side the pump , just trying to figure out where the return pipe will attach on to .
maxfield
AFAIK all e30 Injection pumps are the same.
The actual pumps are the same, but the mounting frames are of two types, depending on the tank size.maxfield wrote:AFAIK all e30 Injection pumps are the same.
The 55 litre tank needs a pump assembly with two pipe connections on it. The 325 pump only has one.
Grrrmachine
- E30 Zone Wiki / Team Member
