heater blower only works on 4
eddybear
Thu Dec 29, 2011 11:20 pm
As the title. My heater only forks on the max setting (4)
Any suggestions?
TouringTash
Thu Dec 29, 2011 11:23 pm
use the search function or at least have a look through the tech thread titles for solutions. or how about the wiki setion ffs
318i Touring
eddybear
Thu Dec 29, 2011 11:26 pm
Did do a search but couldn't find anything. I'll have a look in the wiki section now.
Cheers for the help, ffs
Thu Dec 29, 2011 11:40 pm
There were two threads in the last week, IIRC.
Fan motor is dying through lack of lubrication, and has killed the resistor pack for the slower speeds. If you're lucky, a clean up of the thermal cut out contacts on the resistor pack may save it.
eddybear
Thu Dec 29, 2011 11:48 pm
Not used the Wiki thing before, and think i need a bit more practice.
Did find something about cleaning or replacing the resistors though, so i'll have a look at that.
Cheers Brian.
eddybear
Fri Dec 30, 2011 5:04 pm
I had a look at the fan motor today but couldn't seem to find the resistor board to give it a clean. I hadn't seen any pictures, so wasn't 100% sure what i was looking for. Having just looked at some pics online, it seems to sit under the motor. Unless i'm going blind there definately wasn't anything there. Would the motor work at all without the resistor board? Wondering if the previous owner took it out, as the fan has only ever worked on 4 while i've had the car.
Ranchero
Fri Dec 30, 2011 5:08 pm
Depends on what model e30 you have. Not all resistor packs are located in the same place. It might be tucked up to the side of the glove box.
eddybear
Fri Dec 30, 2011 5:09 pm
Ah ha! I have a 1989 (F) 320i
eddybear
Fri Dec 30, 2011 6:03 pm
Cheers mate, very helpful indeed :D
