MOT- Fail
bigwinn
Post Thu Dec 29, 2011 8:59 pm
Oh dear
So the touring failed on a few minors that I can sort:
OS ball joint
Headlamp aim (HID's not an issue)
But the one that may be out of my hands is the brake pipe corrosion- the main front to rear one that goes over the fuel tank and axle...
Do I have to hand it over to a garage or is this doable?
TIA
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Post Thu Dec 29, 2011 9:02 pm
If you've got the stuff to make up the pipes its do-able.
Mine has had the T-piece relocated to a more accessible position - its getting at it thats the problem with the beam and everything else in the way.
See what a garage will quote to do it - if its cheap enough I wouldnt want to be scrabbling about with it up on Axle stands in December/January :eek:
bigwinn
Post Thu Dec 29, 2011 9:06 pm
£400 so far is the best quote...
Jim320i
E30 Zone News / COTM Team
Post Thu Dec 29, 2011 9:09 pm
Can the brake lines not be run in a new position that just makes it loads easier rather than back over the tank/beam etc? Then just put new in and leave the old there...
bigwinn
Post Thu Dec 29, 2011 9:15 pm
Dunno Jim
I know its going to take a lot of flaring and bending- never done that before so just sounding out how difficult it is without a ramp- or hand it over to the man and smile politely....
Post Thu Dec 29, 2011 9:25 pm
Do you need to use the car on a daily basis ?
If £400 is the best price you can get I'd be following Jim's advice and just run new lines.
Are the hard lines from the T piece and the ones on the trailing arms OK or do these need doing as well ?
I'll see if I can get a pic of how mines been re-done - its not pretty but it went through the MOT without any comment from the tester.
aceifty
Post Thu Dec 29, 2011 9:28 pm
I got all of mine done bout 2 months ago, got all the lines done in copper, braided hoses, and my servo changed for about £200. I supplied the braided hoses and servo. And they were all done the same as the originals are.
bigwinn
Post Fri Dec 30, 2011 7:11 am
cheers gents
will see if I can get it cheaper... and not around the tank...
gaszman
Post Fri Dec 30, 2011 10:38 am
i have a pipe in the garage as i was told this would need changing then i got a wire brush out cleaned of all the crud to find the original pipe has a plastic coating on it to protect the pipe greased it up took it back and told the mot bloke . he had another look and passed it its the plastic coming away from the brake pipe which makes it look like corrosion get under the motor and have a look
Post Fri Dec 30, 2011 11:17 am
Also a good idea/\
A few days before any MOT good plan to clean up all brake pipes under the car with a wire brush/wool and then give them a nice thick coating of waxoyl :wink:
Sanchez
Post Fri Dec 30, 2011 11:27 am
I paid 80quid for front to back copper break line a a garage.
bigwinn
Post Fri Dec 30, 2011 1:08 pm
I'll know to get the waxoyl out next December!
gaszman
Post Fri Dec 30, 2011 3:00 pm
mine is still uin the garage never fitted the thing
mr_dink
Post Sat Dec 31, 2011 2:28 pm
I've done the rear brake pipes on a touring before and the f-r pipe goes around the fuel tank, not over the top of it, so you don't have to drop the tank. It's a bit tight where it goes around the tank but it's possible to route them as standard without removing anything.
I was lucky enough to have a ramp to do it on, I bet it's much harder on the floor.
gazwhittle
Post Sun Jan 01, 2012 11:42 pm
£400 is a mental quote!
it isnt a hard job get a garage to make the pipes for you just take yours off and ask them to copy it.
looking at about £30 for the pipe. £20 brake fluid and £25 for an ezeebleed.
bigwinn
Post Mon Jan 02, 2012 7:55 pm
pipes done, thanks to Malc
Just the welding tomorrow
**BANNED**
Post Mon Jan 02, 2012 11:08 pm
bigwinn wrote:pipes done, thanks to Malc
:o:
