E30 M3 Convertible Replica M30 Turbo
- E30 Zone Meets/Events Team
I bet i'll get my other M30 done before you finsh your first
You probably may well do but it's not about finishing first, it's about getting it done right
I've waiting long enough, what's another couple of days/weeks/months
Dezzy
- CR24v it's a lifestyle
Will this make pod 2012?ImysE30 wrote:You probably may well do but it's not about finishing first, it's about getting it done right![]()
I've waiting long enough, what's another couple of days/weeks/months![]()
Just another deadline for you to miss
No more deadlines, i've learnt my lessonDezzy wrote:Will this make pod 2012?ImysE30 wrote:You probably may well do but it's not about finishing first, it's about getting it done right![]()
LagunaE30
should have bought my vaders bro, bonus is there red from factory
http://www.ebay.co.uk/itm/GENUINE-BMW- ... 860wt_1185
Got mine much cheaper that what you've got yours advertised for, plus I only need the front seats and not a whole interior
I'm growing on the green, it's different and I like to be different
leeparkes
Put me down for 4oz bruvImysE30 wrote:I'm growing the green, it's different and I like to be different
Special rate to Zoner's
Gouki
Thats quite a rare colour for an interior seats! Think that could work, may as well try it out, nothing to lose.
Vaders ?
Look more like fookin Yoda's to me
- Homo Hair
capri_rob wrote:
Vaders ?
Gert_8
Good to have you back!
Got a couple of free hours over the xmas holidays so thought I would get a couple of bits done (no pics, too cold
I'm in process of connecting up the radiator, last thing before I can fire it up.
However this looks too close for comfort? It's an aftermarket hose pipe but the same dimensions as the original (near enough lol).
Yes I know it's bright red
staley_turbo
Try putting it the other side of the crank sensor.
I'll try that next
Have you used the original bmw hose?
leeparkes
This/\/\/\staley_turbo wrote:Try putting it the other side of the crank sensor.
Mine goes above the CPS albeit its an E34 hose extended with a bit of pipe.
I don't have that much room in mine
Will it be okay the hose touching the radiator?
leeparkes
You got the engine in pos 3?
Yep, as far back as it goes, might need to make a few adjustments.
leeparkes
The bottom hose bends away as soon as it leaves the stat housing to go over the CPS. Id fook that red hose off.
Is that the hose Driftboy was using?
It's a bendable (is that a word?) hose, flexi type so I can shape it to fit.
Nope, he sold his rad set-up before he sold me the engine conversion.
leeparkes
Is the engine running in this?
Not yet, need to get the rad connected up before i can start the engine.
It's the last thing left to do engine wise
leeparkes
You can fire it up without the rad on but dont run it for long.
I'd rather not risk it, knowing me i'll blow something up
Need to put some oil in and connect up ECU, might have a go Friday afternoon as i'm off work
- Homo Hair
You'd have to have it running for ages to do any damage..
staley_turbo
Yes I did, cut it down slightly. I think you do have that much room its just under the turbo like mine so it looks very full. Get it running!ImysE30 wrote: Have you used the original bmw hose?
Going to have a go tomorrow afternoon, fingers crossed
How much oil does it take?
leeparkes
Iirc its about 5-6 litres
I think I bought 5 litres a while back from Halfords, might go get some more just to be safe.
Is there anything I should look at when starting it for the first time, any hints/tips on what to do/look out for?
Dezzy
ImysE30 wrote:I think I bought 5 litres a while back from Halfords, might go get some more just to be safe.
The nearest lighthouse's fog light location is a must at this time of year!!!!
I don't get..Dezzy wrote:ImysE30 wrote:I think I bought 5 litres a while back from Halfords, might go get some more just to be safe.
The nearest lighthouse fog light is a must at this time of year!!!!
leeparkes
Turn the engine over by hand a couple of times then turn the engine over by bridging pins 11 and 14 in the round diagnostic socket to get some oil circulated before you fire it up.
appletree
Have a fire extinguisher near by or at least a hose pipe just incase. Once its run a little stop it and check for leaks underneath and check the fluid levels.
redcar
Checking on the floor for leaks is a good idea . Hopefully there won't be any leaks though!
