What have i done now
Post Wed Dec 28, 2011 5:40 pm
a few weeks ago i tried removing the starter motor of the m40 touring for my 316i compact however didnt bother in the end, anyway today i reconnected it up and went to start car all ok however after a bit of turning over battery was dead.
Fitted new battery which is 100% charged nothing wrong, i go to start car and i hear a very quiet click from starter, and now and again a flash comes from it :S
Kind of stumped as it was working fine ten mins prior
ive tried all the wires and there on properly
I'am guessing the wires all correspond in sizes the smaller to the 8mm nut the middle one to the 10mm nut and the larger to 13mm nut
Any ideas need to move the car :S
Post Thu Dec 29, 2011 7:09 pm
No one, if ive put the wires the wrong way round can it wreck the starter, although it worked fine before.
sweep
Post Thu Dec 29, 2011 7:16 pm
Is the earth ok alex?
Post Thu Dec 29, 2011 7:17 pm
which one with the earth :o: is it the thick bare wire on it?
does the whole thing not earth of the gearbox
Touring_IOM
Post Thu Dec 29, 2011 7:27 pm
You should have two small wires and a thick one?
Mine is setup so the thick one is in the middle the small wire if laid flat would be nearest the firewall goes to nearest the engine block and the other small wire facing the nose of the car would be put on the one nearest the wing the side the starter motor is on.
Quite hard to explain but I hope you understand. :D
Post Thu Dec 29, 2011 7:38 pm
interesting, will have a look on sat and see whats what, cannot understand as it worked now it doesnt :?
Post Thu Dec 29, 2011 11:24 pm
If a flash comes from the starter terminals occasionally, there's probably corrosion on one of the connections (most likely the outer 13mm one).
Disconnect the lead and clean things up.
There's no earth lead on the starter motor. It earths through its fixing bolts to the gearbox, then via the engine to the engine to body earth lead on the engine mount or the sump.
Corrosion can also affect the electrical continuity of any of the above. Unusual, but not unheard of.
Post Sat Dec 31, 2011 5:33 pm
Problem solved,
was a loose wire :o: i sware i checked them all though :mad:
Note to self, give up when it gets dark :o: :o: :o:
Post Sat Dec 31, 2011 6:49 pm
Sometimes dark is good - like when you're looking for electrical shorts :mad:
Post Sat Dec 31, 2011 6:59 pm
:D Got the donk running, started straight away think i might leave the m40 donk in seems like such a shame, its not even ran in, and its bar far the quickest m40 donk ive been in and its an auto
need another shell for this engine :mad:
Plus i'am going back to college to finish off my motor vehicle level 2 and 3 so going to be skint again :cry:
