Front suspension ball joints
FEP
Post Wed Dec 28, 2011 1:27 am
Am I right in thinking that if either ball joint is donald ducked then I need to buy a replacement wishbone - that you cannot buy the ball joints and get them pressed into the old wishbone?
TouringTash
Post Wed Dec 28, 2011 6:52 am
whole wishbone fella.
May as well take the plunge and grab 2 along with some M3 excentric bushes as well.
The money would only be wasted on you getting wasted on NYE. best mod you can do on an E30
318i Touring
Post Wed Dec 28, 2011 8:19 am
Sure you can buy replacement balljoints - its only the Alloy arms on the Tourings that can't have the balljoints pressed out ( not that most Tourings are still on their original alloy arms )
If its just the balljoint thats knackered they're only a few quid whereas a new lemforder arm is about £50 ( comes with the 2 x balljoints ) - but then you're also into the realms of spending £40 on new lollipop bushes plus getting the old ones pressed out/new ones pressed in etc.
TouringTash
Post Wed Dec 28, 2011 9:26 am
Go with Robs advice as once again a so called BMW specialist has told me a pack of lies.
Thanks for the correct info Rob.
318i Touring
**BANNED**
Post Wed Dec 28, 2011 9:55 am
Tool that is needed to swap a balljoint costs around £100.
Balljoints are about £10 each.
Complete decent quality wishbone is about £50.
Pair of M3 type eccentric bushes about £25.
Do not attempt to fit new balljoints to an M3 alloy wishbone,dealer only at about £150.
Youth is wasted on the young.
Post Wed Dec 28, 2011 10:13 am
daimlerman wrote:Tool that is needed to swap a balljoint costs around £100.
4lb lump hammers are expensive in your neck of the woods, Malc.
Post Wed Dec 28, 2011 10:23 am
Genuine BMW M3 Eccentrics are just under £40 a pair now with discount - I bought some about 6 months ago.
lemforder balljoints and complete arms available via our Zone ECP contact meatballs82
Malc I'm sure the genuine Alloy wishbones are a lot more than £150 a side - IIRC when I enquired about genuine alloy arms for the Touring they were over £250 and that was nearly a Year ago :eek:
Personally I'd buy the balljoint(s), get the arm off, and take it to a local garage and offer them a pint to press out the old joint and put the new one in :wink:
**BANNED**
Post Wed Dec 28, 2011 10:25 am
Although I an an advocate of using a bigger hammer....
http://cgi.ebay.co.uk/ball-joint-remove ... 24&afsrc=1
This is the correct tool for the job.
mrLEE30
Post Wed Dec 28, 2011 10:28 am
a hammer is the correct tool for every job.
fixed for you Malc
**BANNED**
Post Wed Dec 28, 2011 10:36 am
mrLEE30 wrote:
daimlerman wrote:
Brianmoooore wrote: 4lb lump hammers are expensive in your neck of the woods, Malc.
fixed for you Malc
It is this type of behavour,FROM A TEAM MEMBER,that I so dislike about this forum at the moment.
gooner1
Out humping Reindeer
Post Wed Dec 28, 2011 10:46 am
Lighten up Malc, anyone with a brain cell can see it was meant in jest.
adit
Post Wed Dec 28, 2011 11:39 am
have you ever eaten here Malc? it's very nice i hear :
[quote="bss325i"]
mrLEE30
Post Wed Dec 28, 2011 2:48 pm
daimlerman wrote: It is this type of behavour,FROM A TEAM MEMBER,that I so dislike about this forum at the moment.
Are you really serious?
Speaking as a long time E30 zoner, nothing to do with the team, as i am surely allowed to do, unless perfroming disipliniary measures, i find your reply personally quite childish if not also meant in jest.
So its either meant in jest, or its the end of the matter as far as i am concerned - unless you want to complain about my behaviour then please go ahead.
FEP
Post Thu Dec 29, 2011 1:55 pm
Thanks. Now located the ball joints at ECP.
Malc - don't worry, these are for my Tech 1.
Couple of people have said that the Lemforder wishbones are £50. What am I doing wrong? Basic ones are £58.20 and Lemforders are £76.80.
**BANNED**
Post Thu Dec 29, 2011 2:18 pm
FEP wrote:Thanks. Now located the ball joints at ECP.
With Lemforder's at that price,buy the tool and get stuck in!
I have replaced the wishbones complete on my cars,then discovered the correct tool for the job,but calculated that I would need to swap three balljoints to reach breakeven...with decent wishbones at FEP's quoted price this does change things.
I do use a big hammer,but I have never found one works for me when dealing with ball joints,I split 'em with a scissor type tool.
And MrLee,please keep your clever wisecracks to the proper parts of the forum!
Post Thu Dec 29, 2011 2:19 pm
Nearly always around 25% discount available at ECP, which brings it back nearer the £50 mark.
Post Thu Dec 29, 2011 5:41 pm
Yep - I bought Lemforder arms earlier this year and they were £50 a pop via the zone ECP contact - free delivery as well when you spend over £100 in one go.
