Hi there, recently got a e30,
I keep getting water in the boot, in the side where the battery is and also the other side, I have just patched that size due to rust so i don't want this to happen again! What could be the issue and why does it keep getting water in?
Water in the boot
Rear light seals very common culprit - available but only from BMW and not cheap - about £35 - £40 for the pair
Boot seal - although you may be able to adjust the lid to shut a bit tighter against the seal - if the lip seam under the seal is rotten though forget it
Aerial
If it is a sunroof fitted car the drain tubes may be draining into the boot rather than out through the vents.
Or this :
Drivers side
Passenger side
Aerial
Or this :
Drivers side
Passenger side
phi1
it's solid, i have just put a new battery tray in it! it does have a sunroof tho, so I need to check the rear lights the boot seal (the lip is like new) and where do the sunroof drain pipes go?
Sunroof drain pipes go onto the vents that are on the sides of the boot, covered by the sides of the rear bumper. Aerial drain tube goes to the LH one as well.
Strip out the boot liner (needs a bit of force - it won't break) and sprinkle some talcum powder around. Drive the car, and tracks will form in the powder showing exactly where the water is coming in.
Note that any slight orange stain on the inner wings is likely to be a large hole, after a bit of prodding.
adit
also, there is a small drain hole in the bottom of each "well". these are often clogged with underseal/mud, etc
[quote="bss325i"]
