Very low emmissions - Running lean ?
Post Fri Dec 23, 2011 7:40 am
MOT Tester commented yesterday that the turd is running "lean" with CO of 0.22% and HC of 119.
I havent touched the engine since I bought it and will be replacing the dizzy cap, rotor arm, plugs, blue temp sensor, cleaning the TB / TPS, and getting the injectors cleaned as a matter of course as part of a mild overhaul.
Is the "lean" running likely to be down to an AFM issue ? It doesnt appear to have been tampered with - is there anything I can do to clean it without knackering it up - obviously I don't want to make it worse or disturb any settings.
greg124
Post Fri Dec 23, 2011 9:51 am
Could be caused by air getting in after the AFM
Schadenfreude - the German's haven't got a word for that.
Post Fri Dec 23, 2011 10:05 am
greg124 wrote:Could be caused by air getting in after the AFM
Very likely. Check the rubber cap on the 'spare' spigot next to the TPS.
There's nothing to suggest an AFM fault (or the blue temp sensor, distributor cap, rotor arm and plugs either), but rebuilt injectors and the rest of your overhaul is a good idea (add the injector loom plug and socket to your list - make the BMW mod. of cutting a hole in the rubber boot), then check the gas figures again.
Post Fri Dec 23, 2011 11:16 am
Thanks for the advice Brian
Is this "spigot" easily visible - and is this rubber cap you mention likely to be missing or just perished ? Sorry to sound vague but I'm not really sure what I'm looking for :o:
The plug and socket you mention this is the one under the inlet manifold which is known to cause starting issues yes ?
Not come across this mod of cutting a hole in the rubber boot before - what is the purpose of this ?
I'm only changing the ignition components as I have nearly new ones in stock and the ones on the car look like theyve been there a loooooooong time :(
Post Fri Dec 23, 2011 4:38 pm
The spigot with the rubber cap is on the underside of the throttle body, and almost touching the TPS. As such, it's just about impossible to check in situ - a job to be done while you have the throttle body off while checking out the TPS.
The plug and socket are the one you describe, and the hole cut in the rubber boot is described in a BMW TIS. The hole is to let any water that gets in there out again.
Re the ignition components; if they show any physical sign of deterioration they should be changed, but I don't think they're contributing to any fault - yet.
Post Fri Dec 23, 2011 4:41 pm
Thanks Brian - will report back soon :D
TouringMatt
Post Sat Jan 21, 2012 1:06 pm
Did you ever manage to sort this Rob?
Had my MOT today, CO was uber lean at 0.25%, HC was 172. Tester said he could smell it in the exhaust fumes.
Car drives fine, but did notice a very slight stutter above 5k revs when with WOT in 3rd today, seems odd, everything has been replaced over the past 4 years on the inlet side as well :cry:
TouringMatt
Post Sat Jan 21, 2012 1:13 pm
Doh, just found last years, CO 0.16%, HC 244
Year before, CO 3.00%, HC 256
Its been that way for a while then :roll:
bmw9818
Post Sat Jan 21, 2012 2:49 pm
hold up? i thought low CO and HC is supposed to be good? 8O
first mot 2010 it was 1.02 HC - 286ppm most recent mot is CO - 0.16% and HC - 723ppm.......
so my car is running rich?
Sanchez
Post Sat Jan 21, 2012 3:10 pm
Mines was a lot higher and fail emissions big time. Fuel smell in the exhaust but good mpg on a run.
Post Sat Jan 21, 2012 9:36 pm
bmw9818 wrote:hold up? i thought low CO and HC is supposed to be good? 8O
HC =723 ppm is definately not healthy. The low CO reading and high HCs implies that you have an air leak.
Ideal readings on a healthy non cat turd are CO 1% , HC less than 200 ppm. Higher ppms indicate lean mixture / air leaks or misfires.
Post Sat Jan 21, 2012 9:38 pm
Found the cause - forgot to tighten both big jubilee clips on the AFM bellows :o:
What a tw@t :o:
Sanchez
Post Sat Jan 21, 2012 9:44 pm
at least you found the answer.
TouringMatt
Post Sat Jan 21, 2012 11:48 pm
How does that make my results sound? HC sound ok-ish at 172, but the CO is really low, still pointing towards air leaks?
e301988325i
Post Sun Jan 22, 2012 11:09 am
CO is what you use to tell how the mixture is set.
HC's are a measure of unburnt fuel, too lean a mixture (low CO) and it won't burn fully/cleanly, ironically this is also true of too rich a mixture but the CO value will be higher.
The AFR (air fuel ratio) for petrol needs to be very accurate for a good burn and healthy running, this is where LPG is so much more tolerant of mixture variations.
Aiming for 1% CO for an M20, if this is correct and HC's are still up then ignition components or compression are suspect.
edit :o:
I said:
e30topless said:
lock the wife in there
Post Sun Jan 22, 2012 4:32 pm
CO = Carbon monoxide.
CO2 = Carbon dioxide.
Two very different gases, and both produced by an internal combustion engine, and I'm fairly certain that the above post should read CO and not CO2.
CO2 levels tail off either side of the 'ideal' fuel/air ratio, reaching a peak at that ideal.
CO levels are high with a rich mixture, falling rapidly as the mixture reaches 'ideal', then only falling very slowly with progressively leaner mixtures.
kam-325i
Post Sun Jan 22, 2012 5:05 pm
HC = HydroCarbon = Unburnt Fuel
