Tips for splitting a prop
Kedge
Post Thu Dec 22, 2011 1:30 pm
Proper dumbass question this but i'm getting cheesed off now............
Need to change the center bearing on my prop while it's out of the car but i just can't get the prop to split, do they have a tendancy to seize?
I've got the collar nut undone, it's had WD sprayed down the splines last week in a hope that would soak in a losen it a littlebut it's still not budging!
Instagram - Kedge85
Kedge
Post Thu Dec 22, 2011 2:16 pm
That's no bother, it's still got the original markings on it.
As far is i understand, you just undo the collar nut and they slide apart but this seems pretty well stuck.
Instagram - Kedge85
maf260
Post Thu Dec 22, 2011 2:36 pm
I may be confusing this prop with one from another car, but have a look to see if there's a circlip buried in there somewhere...
Kedge
Post Thu Dec 22, 2011 2:40 pm
There's one that secures the bearing but that shouldn't stop the prop splitting, have undo that already incase though.
Instagram - Kedge85
gooner1
Out humping Reindeer
Post Thu Dec 22, 2011 2:59 pm
http://www.realoem.com/bmw/showparts.do ... g=26&fg=10
Not sure if this helps mate but can't do any harm.
Kedge
Post Thu Dec 22, 2011 3:11 pm
Just kinda confirms it is just seized in place i think Rob, i've had heat on it a couple of times and have now left it stood up with a load of WD in a hope it can soak down the splines. Need a new collar nut now though as i never realised they had plastic inside them :roll:
Instagram - Kedge85
Post Thu Dec 22, 2011 5:41 pm
Do you have a well fixed vice? You can put one end in the vice and with a foot on the vice give it a good tugging.. 8O
