immobiliser
wafuboy
Post Wed Dec 21, 2011 6:36 pm
Hi, my e30 seems to have an after fit immobiliser on it that is VERY hit and miss. so ive decicded to remove it. ive followed the leads back and the go into a control unit above the glove box with a double fuse. has anyone come accross this type before and if i disconnect it here will this end the issue with it as i cant find any elec cables going into bonnet area to the battery, please help!??? :mad:
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Dec 21, 2011 6:51 pm
really need to know some wire colours; your description is a bit vague!
The sorts of immobilisers fitted to E30s are usually quite basic, in that they interrupt the solid green wire that goes to pin 7 of the C101 engine plug; the ignition wire.
Look for that, and report back.
wafuboy
Post Wed Dec 21, 2011 6:54 pm
thankyou very much for your help and a speedy reply grrrmachine!!!!! ill get on it for the colours. but the immobiliser has to have a little fob round in shape held up to and touch a "female" insert on the dash centre consol with an led next to it????
wafuboy
Post Wed Dec 21, 2011 6:59 pm
hi just been back out to the car. the elec plug going into the control unit has 12 wires going into it via a plug. 9 are solid black in colour the other 3 are 1 red, 1 blue, 1 green. ???? im stumped with this??
Grrrmachine
Post Wed Dec 21, 2011 7:11 pm
Not interested in what colours go to the control unit, it matters what wires in the original loom they interfere with. I expect you'll have to get the screwdrivers out and remove the glovebox to have a proper look at the loom.
There's a hundred and one mobilizers out there, so we couldn't just say "cut the red wire" like they do in the movies. You just need to unf#ck whatever it is the original installer f$cked up in the first place.
If you don't want to wait for another reply, do a search for "GREEN WIRE IMMOBILISER" in the technical help section.
wafuboy
Post Wed Dec 21, 2011 7:29 pm
hi thanks again for your help, ive have removed the glovebox, the unit im talking about was in a steel case. the plug is like a bigger radio plug but white in colour, it has the wires going to various bit of the immobiliser like the fob female and there is also a black box that has been stashed under the centre consol near the gear stick that has a green led on it. the other wire goes into the bonnet area but i cant seem to find it in there, so im assuming this is the power supply cable??
Post Wed Dec 21, 2011 8:35 pm
The first thing I need to know is what happens if you try to start your car with the immobiliser engaged.
Do the warning lights in the cluster all come on when you switch the ignition key on?
Does the engine crank if you turn the key to the start position?
If the answer to both of these is "yes" connect a piece of wire from the battery + terminal to the ignition coil + terminal (without removing any of the wires already connected), and see if the car will start.
It would also help if you told us what E30 you have!
wafuboy
Post Wed Dec 21, 2011 9:05 pm
lol thanks again for your help!!!!! im really sorry very new to forums... as you may have guessed....the car i have is a 320i cabriolet. m20 b20 engine.
to answer the questions asked, if the immobiliser is engaged the instrument lights work but the car doesnt turn over just makes a clicking noise.
i have done some more wire chasing and found the a bmw wire has been cut and this immobiliser seems to be ran from this cut wire with a wire going into the plug and one coming from the plug back to the bmw wire.
the wire that seems part of the car is coloured black and yellow. i am tempted to melt the solder on the fitted wires and connect the original wire to see if this cures the issue... but as im about as good at auto electrics as i am at using this forum ill wait till a guru can shed any light on it..!!!!!!!!! THANKS IN ADVANCE.
while im at it how do i find members local to me to get together with??
Grrrmachine
Post Wed Dec 21, 2011 9:20 pm
That black/yellow wire runs from your starter relay to your starter motor; a break in that will definitely be stopping the engine from turning, but you can hear the starter relay clicking as it tries to turn on the circuit.
Cutting off the wires and soldering the two ends of the black/yellow back together would be a start, but if there's 12 wires going into your immobiliser box, you need to know where the others are going as well.
Post Wed Dec 21, 2011 9:46 pm
Reconnecting the two cut ends of the black/yellow is the first thing to do. This is the start signal wire, and runs from the ignition switch (plain black for the first several inches, until it reaches a plug and socket that should be clipped half way down the steering column,) and then black/yellow all the way to the starter motor, unless your car is an auto. Alternatively, as a test you can always crank the engine by linking together pins 11 and 14 in the diagnostic socket
If the car will then crank, but not start, (with the ignition on), check to see if there is 12 volts on the coil + terminal. If not, connect the wire between the battery + and coil +, as I said earlier. If there is power at the coil +, then there's probably a second immobiliser circuit connected in the fuel pump feed.
wafuboy
Post Wed Dec 21, 2011 10:31 pm
hi thanks again you dont realise how much your helping me!!! god knows how you know all this tuff but its great to hear from some obviously very clued up guys!!! the yello and black wire that is cut is the only break in any wires the other wires all lead to the fob unit and earths. ill cut this and re join it and then see what happens. if its ok ill pm you 2 to let you kno what happens and for any further advice as your really clued up would that be ok??
Sanchez
Post Wed Dec 21, 2011 10:34 pm
Brian is the wiring guru of the zone, he is the zone 'Daddy'.
Post Wed Dec 21, 2011 11:16 pm
If the black/yellow is the only one cut, then try linking pins 11 and 14 on the diagnostic socket before you disconnect anything.
The diagnostic socket is the large round socket at the top of the engine at the front, with a screw cap on it. Unscrew the cover, carefully identify pins 11 and 14, turn the ignition on, make sure the car is out of gear, and use a short piece of wire to link the two pins together. The car should start.
That's how easy it is to bypass these immobilisers!
Grrrmachine
Post Thu Dec 22, 2011 5:33 am
Here's the diagram, so you know what the Diagnostic Plug looks like, and which pin is which:
http://www.e30zone.net/e30zonewiki/inde ... ostic_Plug
You should have the "pacman" style plug.
