no. plate lights dont work (325 tourer)
danhtid
Post Wed Dec 21, 2011 5:20 pm
as above, i have changed the bulbs to no avail and using an electrical tester there is no power coming thru the wires. also my clocks do not iluminate when the lights are on. is there a fusebox inside the car? that could be causing this problem or is it a case of chasing wires and looking for damage?
help would be much appreciated
cheers dan
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Dec 21, 2011 5:36 pm
TourING, not tourer.
Wiring diagrams are in the wiki, I'll be uploading Cabriolet and Touring ones soon(ish). Check out the Dash Lights:
http://www.e30zone.net/e30zonewiki/inde ... g_Diagrams
and if you look at the Lights section of the Wiki, you can see that
"(the license plate lights) are fed by the same grey/red wiring that powers the interior lights."
Post Wed Dec 21, 2011 6:19 pm
Check fuses first.
Fusebox in the engine bay.
Fuse number 23, 7.5amps - for the circuit which controls number plate lights AND instrument lights.
Post Wed Dec 21, 2011 8:27 pm
capri_rob wrote:Check fuses first.
BUT this fuse is also for the RH rear and front parking light as well, so the fuse can't be at fault.
If the panel lights are out as a result of the same fault that's killing the number plate lamps, then, assuming no one's been 'playing' with the wiring, about the only thing that I can think of that can be at fault is the lighting switch itself.
Power goes into the switch, from fuse 23, on a grey/green wire on pin 7, and comes out, in switch positions 1 and 2, on a grey/red wire on pin 1 to feed the panel lights and number plate lights, and on a grey/white wire on pin 5 to feed the RH front parking light and the RH rear tail light.
danhtid
Post Thu Dec 22, 2011 1:31 am
cheers guys will give it a look over tomorrow
