Good site on throttle cable replacement
xavier
Can anyon point me in the correct direction for a good site/ thread/ page on replacing the throttle cable on my 323 I? It snapped at the point near the throttle body. Fun driving home at 5 kph
The only tricky part is removing the plastic clip from the bulkhead.
You need to get up at the back of the pedal box and depress both plastic tabs to pop the clip out.
The cable at the pedal end is just a hook through a rubber bush which pulls out.
Its not particularly hard just fiddly.
To prolong the life of the next cable soak it in 3 in 1 oil before fitting.
You will notice a vast difference in drivability with a freely-moving cable
xavier
Thanks, but sorry to appear dim, but what is 3 in 1 oil?
Sorry - just normal basic oil that you'd use for lubricating door hinges - comes in a little metal or plastic bottle from any car spares placexavier wrote:Thanks, but sorry to appear dim, but what is 3 in 1 oil?
Classic!diable wrote:clicky here
suedenim
Take some photos before you remove the old one, route of cable, fixing at throttle etc. I agree on the plastic clip at the bulkhead, it's fiddly to remove because of where it is, ended up just cutting it up with a sharp chisel and hammer
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
