Post
Sun Dec 18, 2011 5:45 pm
You do realise that there are tweeter wires already fitted? They end at two small spade connectors behind the door panel, just below the mirror trim.
To answer your question: Pull back the rubber boot, pull out a small plastic piece right in the middle of the plug, squeeze in the tabs each side (these were locked in place by the small plastic piece you just removed), then pull on the tabs.
I usually use a pair of pliers on each tab to pull the plug straight out.
When you refit the plug, the rubber cover must be in place before you refit the plug, otherwise the cover won't locate properly and leaks will ensue.
