Electric window problem.
ah
Post Sat Dec 17, 2011 6:52 pm
My f/o/s/ window has a fault on it.When it starts to go down,it works fine until it gets approx half way down and then it slows right down until it practically stops.After the half way mark it speeds up again but still slow until it gets to fully open position.Closing the window is the fault in reverse.Anyone got any ideas
turkeysneck
Post Sat Dec 17, 2011 7:01 pm
Got the same problem with mine, the tube the cable runs in is tight in one spot. That's if it's the early type of window mechanism. You can widen the channel but it's time consuming and annoying.
Post Sat Dec 17, 2011 8:14 pm
turkeysneck wrote:That's if it's the early type of window mechanism
This is the first thing that needs to be established.
ah
Post Sat Dec 17, 2011 8:17 pm
Sorry I would'nt know but the car is a June 1990 320i cab,if thats any help.
SGP
Post Sun Dec 18, 2011 2:29 am
Must be the early type if it's a chromie ?
If it ain't broke..
Fix it till it is :)
mrLEE30
Post Sun Dec 18, 2011 7:13 am
look in the wiki guide on adjusting front windows, and rub a little silicone grease inside the rubber window guides.
It could just be misalignment or a sticky window.
If that does not help then take a photo of the mechinism with the plastic sheet pulled back, being a cab and a later one it will likely have the later type widow winding mechanism
