Water in boot
greg124
Post Sat Dec 17, 2011 9:23 am
I notice this week that a small quantity of water had collected in the well at the passenger side of the boot, where the bottom of the jack sits.
Where is/are the most likely places for this water to be getting in? The rubber seal around the boot looks to be in good condition.
Schadenfreude - the German's haven't got a word for that.
torquey
Post Sat Dec 17, 2011 9:32 am
Ariel is a prime suspect
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Dec 17, 2011 9:41 am
Surprisingly, the rubber seal around the lights is also a big issue.
Do you have a sunroof? The rear drains come down rubber pipes to plastic "vents" in the rear quarterpanel, and sometimes these rubber pipes pop off, allowing roof water to drain into the boot.
If it's none of those things, it'll be a rust issue unfortunately, although the passenger side is a lot less prone to this than the driver's side...
Post Sat Dec 17, 2011 10:20 am
Pull the carpet out and make sure the inner arch is intact :eek:
hammoj28
Post Sat Dec 17, 2011 10:27 am
Pull the rubber boot lid seal off and see if the lip holding it on has rusted?
24v tech2
greg124
Post Tue Dec 20, 2011 1:53 pm
Thanks guys.
It is a sunroof model, and there was some moisture around where the drain tube pushes into the 'vent'. Pulled the tube out, cleaned the end, made sure the vent wasn't blocked before firmly re-inserting the tube. Made sure water runs away without getting into the boot - via this route!
Pulled the rubber seal off the boot lip, and there is no rust there, and no signs of rust in the inner arch or well.
I guess that just leaves the aerial or the seal around the lights. need to wait until it rains again to make sure.
blackrs2000custom
Post Tue Dec 20, 2011 7:04 pm
I have the same problem, sealed my ariel with sealer and still leaking, clean water so it must be from above and its coming down the rear pillar, i suspect sunroof area but to cold to investigate further.
aceifty
Post Tue Dec 20, 2011 7:16 pm
if you have a spoiler it could be coming from there, make sure that the bolts are tight
xavier
Post Thu Dec 22, 2011 1:56 am
I had the same problem. After much farting about and trying different things i found It was the seals on the tail lights. I got new tail light seals and once the lenses where in added some good quality silicon sealer in the gap all around. Smooth the sealer so that it does not trap water. This stopped the water getting in. An extra help is to get rid of the carpet on the side under the jack and put in bigger drain holes, this gets rid of anything that might still get in or be spilled in the boot.
suedenim
Post Thu Dec 22, 2011 10:53 am
Same problem on mine although I don't have an aerial :cool: will look at the other places after christmas.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
