alternator correct voltage rate
bmw9818
Post Fri Dec 16, 2011 4:25 pm
just tested my alternator, the rate showing at idle is around 13.7 picking up the revs to 4k it goes to about 13.9, is that not the usual rate? its close to 14v thats with heaters, radio, heated seats, lights all on,
battery is usually dead in about 1-2 days when not driven, batt was recently replaced 5 months ago as old one did the same that was also new and conked out in the same timeframe 5-6 months,
on monday after a 30minute drive in the morning (low revs eco driving), heated seat/ radio was on low vol, the batt died after 10minutes in the car park,
Also few days ago the car started stuttering unusually when i was driving along, then at the traffic lights, headlights/ radio started dimming, put it in neutral revved the beans off it and it was back to normal, it was orite after that for the remaining journey,
was thinking to replace the brushes but the charging rate looks okay, battery is new but budgetish brand still cost around £60, grounds all look okay as well,
anything sound familiar that i can check, doesnt seem to be anything majorly draining the battery when off, getting tired of jumping it in the uni car park, some fit honeyz driving past in their new cars, and im standing sparks flying tryna jump it :cry:
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Dec 16, 2011 4:39 pm
That's not great. At 4k revs the alternator should be chucking out half a volt more, 14.4V and yes, that will make a difference. I'd definitely get it swapped for a known good one.
bmw9818
Post Fri Dec 16, 2011 6:55 pm
cool il give it a shot, should have a spare alternator somewhere,
HairyScreech
Post Fri Dec 16, 2011 9:01 pm
its a bit low, check your brushes and regulator pack, there about £30 and piece of piss to change.
really you should be 13.5v min at idle and 14+ on a rev.
johnl320
Post Fri Dec 16, 2011 9:14 pm
I had a similar fault many moons ago and it was corrosion on the alternator mount preventing from earthing properly. I took it off, emery clothed the mating surfaces and problem solved. You may have a rubber mounted alternator which has its own little earth strap, check the condition of it and clean the contact surfaces
milescook
Post Sun Dec 18, 2011 5:01 pm
Ha I've just been round the alternator conundrum, replaced it and belts. Turns out my belt was way too slack so it wasn't driving the alternator properly!
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Post Sun Dec 18, 2011 6:53 pm
johnl320 wrote:I had a similar fault many moons ago and it was corrosion on the alternator mount preventing from earthing properly.
Many perfectly serviceable alternators are replaced because of this! Of course, the act of removing the old alternator and bolting up a new one solves the connection problem (in the short term at least), and no one is any the wiser, least of all the mug who's paying the bill.
The test, which should be made before anything is disturbed, is to check for any voltage between the alternator frame and the battery negative terminal, with the engine running.
