1990 320i clutch problem help please
teatime39
Post Fri Dec 16, 2011 2:35 pm
Yesterday i jumped in my 1990 320i cabby for the first time in about 2 months , i drove for a few miles then as i was doing around 30 -35 the clutch pedal went soft with just a little pressure so i kept my foot on it and it went right down but did not engage the clutch , the car carried on . i let the pedal go and it stiffened up again and the clutch worked again ,drove a little further it was fine , after a couples of miles and it did the same thing , what could it be ?
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Dec 16, 2011 2:38 pm
Clutch or Master cylinder failing, and letting fluid get past the internal plunger.
Even if you identify which one has failed, you need to swap them as a pair.
teatime39
Post Fri Dec 16, 2011 2:57 pm
is there anyway of testing this
