heater fan
imye30
as above not working on setting 1 bit works on all the others
Motor is partly seized. Remove it, free it up, oil it, run it outside of the car on a battery, repeat until it is completely free, then refit to car.
Been detailed on here many times, and may even be in the wiki.
Ignore the problem, and you will destroy the heater speed resistor.
imye30
cheers will look it up thanks
adit
i've had this usual problem too.
on the coldest mornings so far, it has only worked on speed 4 for a couple of minutes, then when the car has warmed up a little, i selected speed 3, then 2, then 1 and it worked on all speeds.
just takes a little while to warm up these days...no comments Rav
[quote="bss325i"]
Brianmoooore wrote: Ignore the problem, and you will destroy the heater speed resistor.
SGP
After 20 odd years, the motor really benefits from a clean up and lube.
If it ain't broke..
Fix it till it is
Fix it till it is
TouringTash
I've had girls like that.SGP wrote:After 20 odd years, the motor really benefits from a clean up and lube.
318i Touring
