Working through the to do list on the cabby and remember that the mot man had an advisory last year that one of the CV boots is split, rear drivers side.
Its a 325 so has rear disks etc.
How do you go about replacing it. As always fearing that what looks like a simple job is going to be a total c**t to do.
Split CV Boot
Rtaylor2208
Rtaylor2208
Anyone?
markgE30
big nut on the hub either a 30 or 32 and the six bolts on the diff.take the big bolt off first so you can lock it in gear then the 6 allan bolts on the diff and the drive shaft will come off.hope this helped. Mark
Unbolt the shaft at the diff end, drop it down, and prise off the cap that completely covers the end.
This will expose a circlip that holds the shaft into the joint. Remove this, and the shaft can be tapped out of the joint, allowing access to both boots.
Rtaylor2208
Thank you both, Sounds a little complicated. I'll most likely be making a start to this at the weekend so will more than likely be back with more questions.
