Unless you specifically connected the stray spark plug lead terminal directly to an electrical connector that just happened to lead to the ECU, I fail to see how just disconnecting the plug leads temporarily could cause any damage.
335i running rich and white smoke!! help!!!
How would this happen exactly?
If you remove all the plug leads, and leave them dangling, they are heavily insulated with a deep rubber shroud (the actual terminal being buried some 2-3cm up the shroud) so the worst that could happen is that it arcs to a metal point in the engine bay, which is effectively what happens anyway when they are connected to spark plugs fitted to the engine!
The arcing can take place at the coil itself; either externally from the king pin to one of the two low voltage terminals, or internally. If it arcs to the - terminal, the high voltage is fed directly to the driver in the ECU. Even if it arcs to the + terminal, high voltages are induced into any other wires running alongside that wire. Similar things can happen if a MIG/TIG welder is used on a car, and the earth clamp isn't positioned close enough to the work.
There's a vast difference between the HT voltage when its limited by the spark gap in a plug, and when its just open circuit.
