318iS LSD how to check for 1?
KEFLON
Post Tue Dec 13, 2011 5:42 pm
Hi guys
I did a search on the forums for an answer but came up empty handed.
Im planning on viewing a E30 318iS this weekend.
And wanted to check if the car had an lsd..... just incase the seller dosen't know or is fibbing. what on the spot checks can I make to see if it has 1 and if its the right 1 too?
Am I right in saying that the LSD on a 318is was an optional extra and if so what ratio was available?
Thanks for your help
Faz
Jim320i
E30 Zone News / COTM Team
Post Tue Dec 13, 2011 5:49 pm
This might help you out mate...
And 4.10 Open is I think the standard diff on the 318is...
Barx325i
Post Tue Dec 13, 2011 6:00 pm
an open 4.1 as jim says.. Although rare, iS's were fitted with an optional LSD
If you get the chance, jack a rear wheel up and turn it with the handbrake off and the car in neutral - if it turns freely, he's either fibbing or it's well worn, if it's tight but you can still turn it it's definitely a LSD - if you can't turn it, it could be a welded diff, limited slip but in premium condition, or you didn't eat your weetabix
KEFLON
Post Tue Dec 13, 2011 6:29 pm
Cheers fella's big big help
wish me luck
