Rear wiper problem
adit
Post Mon Dec 12, 2011 10:46 pm
i was a bit annoyed about the rear wiper on my Touring not working.
i thought i would have a quick look, so took the plastic cover off the inside of the tailgate and found the motor was unplugged :screwy:
so, of course, i reconnected it and hey presto, it worked perfectly.
that lasted for about a week until one day i noticed that it was working continuously. how odd. i changed the dashboard switch, but still no better. all the time the ignition was on, the wiper was going :?
is this a relay problem?
TIA
[quote="bss325i"]
beemerbird
Post Tue Dec 13, 2011 11:16 am
Sounds like something could be shorting out a couple of pins on your relay, giving an 'always on' state. It's worth pulling it out to check that nothing metallic is in the holder.
It does probably explain why someone disconnected it!
Post Tue Dec 13, 2011 2:19 pm
It could be either the control module (in the side pocket) or the park switch in the motor assembly, but I've had issues with the park switch before. It's a miniature microswitch mounted on the gearbox cover, and can stick on as a result of old grease.
Disconnect the black/red wire from '2' on the motor to 31b on the control module to check.
adit
Post Tue Dec 13, 2011 10:51 pm
thanks guys
Brianmoooore wrote:It could be either the control module (in the side pocket)...
where exactly do i find it Brian, in the left-hand "cubby-hole"?
[quote="bss325i"]
Post Tue Dec 13, 2011 11:07 pm
Tucked up behind the metal panel, right at the back. The one with only a single plug.
The lamp check module is also in there, if you have one, but that has two plugs.
