SE vs Sport skirts
cee
Can't really find any decent photos to compare, what's the difference?
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
cee
Yeah... Not really relevant though. I'm just talking what the difference is, not which is nicer.
Sanchez
Tech 1 or 2 sport sides?
cee
2, sorry
Sanchez
Best fitted with the whole kit. Plenty pics on goggle images.
cee
Well I searched, but they look the same from the photos I could find. I was thinking about a set of SE skirts to make the sides a bit lower to match the iS splitter...
Sanchez
SE skirts match the IS front spoiler better than tech 2 sides and IS front.
My touring, IS lip SE skirts
My IS. IS lip SE skirts
sunnyr83
cee
Ah, much clearer, thanks!
leeparkes
No skirts FTW.
Kedge
Tech 2 skirts HAVE TO HAVE the door pods fitted as well.
I prefer iS's without skirts!
cee
Well it's between SE Skirts or re-painting the sills as they're currently covered in the waxy black paint and look rubbish!
Kedge
Waxy black paint?! Sounds an odd thing to have painted on there. Should just be black stone chip. If you have good solid rust free sills i wouldn't be drilling them to fit skirts.
cee
It's the stock bubbly black paint that's on the rear bumper as well
Kedge
Then thats just how i'd leave it personally, just a new coat of black to freshen it up.
leeparkes
Id colour code it to make the sills look deeper.
cee
Yeah well that was the idea. No way I'm leaving it black it looks stooooopid
Kedge
IMO that only works on something like yours Lee, for me the contrast with the black sills works on most non kitted cars.leeparkes wrote:Id colour code it to make the sills look deeper.
I had skirts ready to go for my old iS in the right colour but decided against it, especially after someone did me a photoshop, looked too fat somehow. But then fitting SE skirts to my touring has worked, but i think mainly because it's black on black, only bothered as they'd gone missing under previous ownership so the holes were already there.
cee
I just think that the 'sucky in' look of the sides and rear bumper looks stupid when the front goes down and out slightly.
Definitely colour coding if not skirts.
adit
Kedge wrote:Tech 2 skirts HAVE TO HAVE the door pods fitted as well. -DEFINITELY
I prefer iS's without skirts! - DEFINITELY NOT!
(i have SE skirts (black and red) available)
[quote="bss325i"]
cee
So the sills have to be drilled and the skirts bolted on? Is there no way to clip/glue them in place?
mrLEE30
be different..... go Tech 2 BMW Japan styleee
Sterling silver car, Granite Silver lower Tech 2 kit (boot spoiler in sterling silver) this is a factory combiniation and grows on you....(well grew on me!)
polsta
the black stone chip is factory on sills and valanceKedge wrote:IMO that only works on something like yours Lee, for me the contrast with the black sills works on most non kitted cars.leeparkes wrote:Id colour code it to make the sills look deeper.
i had a black is,so it didnt look different like it does on red/white is`s , also like kedge i had some se skirts in black ,but never fitted them, although when holding them on the car they looked ok, although always niggled at me they were not oem, although on the red one above ...can look ok/good, i wouldnt fit sport skirts on a car without the rest of the kit
The skirts are held in place by several push fit plastic fittings along the top edge of the skirt and plastic "clamps" which fit to the lower edge of the sill.cee wrote:So the sills have to be drilled and the skirts bolted on? Is there no way to clip/glue them in place?
To do it properly you have to drill the sills to fit the push-fitting mounts.
Agree with Kedge - if your sills are solid really the last thing you want to be doing is drilling holes in them but if you must make sure that you plaster the holes with decent paint and then waxoyl before you even think about putting the fixings in place.
If you are fitting skirts it makes sense to plaster the whole sill in waxoyl before fitting.
You can tiger-seal the upper edge of the skirt in place to avoid drilling the sill but this is a proper bodge
adit
oh no Rob, pleeeease don't mention Tiger-Seal, you'll get shot down in flamescapri_rob wrote: You can tiger-seal the upper edge of the skirt in place to avoid drilling the sill but this is a proper bodge
[quote="bss325i"]
Wouldnt do it myself but it is a "solution"adit wrote:oh no Rob, pleeeease don't mention Tiger-Seal, you'll get shot down in flamescapri_rob wrote: You can tiger-seal the upper edge of the skirt in place to avoid drilling the sill but this is a proper bodge
MattTheHat325
I used to have colour coded sills and rear valance , as per my sig, but it bugged me as it's just not how it's meant to be. May work well on another colour but mine was looking too White, a bit overkill. They are now black, I'll chuck some pics up when I get home from work.
Tan91
The clips for the SE side skirts are all available from BMW themselves, I've just recently bought my ones you'll need three main components for the fitting of the SE skirts.
Green Plastic Grommets £0.14 Each
Lower Clips 8 on each side £0.65 Each
Upper Clips (push-fit type) £0.42 Each
You'll defiantly have to drill holes for the green grommets and the clips slide into the channel at the top of the skirt, and then pushed into the sill
The bottom one will have to be simply clipped to the lower part of the sill. Very easy.
Prices vary from time to time and if they are not in stock they usually deliver them within 48 hours to the Dealer for you to collect.
I am waiting for my ones to come and will be posting a thread on a Step-to-Step very soon, Hope this helps!
HairyScreech
It's arguably better than drilling a line of holes that wont get proper corrosion protection.capri_rob wrote:Wouldnt do it myself but it is a "solution"adit wrote:oh no Rob, pleeeease don't mention Tiger-Seal, you'll get shot down in flamescapri_rob wrote: You can tiger-seal the upper edge of the skirt in place to avoid drilling the sill but this is a proper bodge
Done right with the holes protected fine, but otherwise its asking for a shed load of trouble when those holes become the perfect places for terminal and structural rot to start.
