hi there i have posted a few times about things with my car.
i have a f plate 1989 2.0i 6 cylinder engine, but only have a single exhaust system, can any1 shed some light on why? i was under the ussumption that 6 cylinder engines are a twin system?
exhaust question
leeparkes
Some 2.0 do have a single system, you can fit a twin system from a 2.5 but im guessing you will need to change the manifold too.
HairyScreech
manifold should be the same, you cant have a 6 into 1 i6 exhaust without one cylinder trying to blow gas back into another's open exhaust valve.
Most of the facelift 320i systems I've seen do have twin pipes - albeit of a smaller diameter than a 325i system.
Does your car have the larger cutouts on the rear valance to accommodate a twin pipe backbox ?
notty
yea it does indeed, do u think the exhaust system has been changed??
Very likely.notty wrote:yea it does indeed, do u think the exhaust system has been changed??
notty
is the single pipe likely to of changed my performance?
Not if it's the correct one for a 2 litre M20. If it's something bodged from a M40 system, then possibly.
notty
how can i tell the difference?
Rtaylor2208
Have a look at www.realoem.com. Go into the site then go to the archive. You can then specify your car, year, model etc etc.
You can then browse the diagrams for the car, in the exhaust section you will see what was fitted to it when new. Might not be exactly the same as you have now but you'll get an idea.
Very early facelift 320s did indeed come with a single tailpipe exhaust and a smaller recess in the rear panel. Most have been weighed or 'upgraded' by now.
aceifty
as his car is on a F plat, doesn't that make it a pre facelift. pre facelift 320s had a single tailpipe. my mate got a D plat 320 all original and one tailpipe also iv had 2 myself
1989 cab M20B28 build
shanehaward
ive got an early '88 facelift and thats the same. single pipe from the down pipe back so will need to cut rear valance when i get a new exhaust. any tips?
