No power at the fuel pump
Cloggy Saint
The one inside the car, at the RH end of the seat pan? About 8 wires, IIRC.
Cloggy Saint
I can't get anyone to look at this problem until after christmas so I've carried on digging around myself. The car starts and runs fine with 12v directly to the pump. I've been looking at the immobiliser which I thought was factory but looking at the wiring it probably isn't. There's the flashing light next to the demister switch with a red, a black and a white wire coming from it which goes to this socket
This has 3 black wires coming from it, 2 of which have socket joins a little further down the line. At this point there are also 2 identical sockets hanging loose. Could this be to bypass the immobiliser as on the factory system? What's the worst that could happen if I join them?
All you have to do to solve this is check every inch of the green/purple wire from the outside terminal of fuse 11 to the fuel pump. A break in this wire is the ONLY possible cause of your problem, if all the test results are accurate.
You still haven't answered my last question.
Cloggy Saint
This question?
To be honest I haven't seen a plug & socket with 8 wires at the right of the seat pan, they must be tucked away out of sight. What do they do? So you think I can catagorically rule out an immobiliser fault?Brianmoooore wrote:The one inside the car, at the RH end of the seat pan? About 8 wires, IIRC.
The plug and socket should be cable tied to the steel tube that has the fuel tank vent pipes inside of it - at the extreme right end of the seat pan.
Unless it's connected to that green/purple wire between the fuse and the pump, "the no power at the pump" is nothing to do with any immobiliser.
If the green/purple is connected to an immobiliser (inside the fusebox?) then there's every chance that an immobiliser is the problem.
