propshaft centre bearing
steve_k
Post Sun Dec 11, 2011 11:21 pm
right then folk's time for a bit of help & advise.
took the car out for a spin on friday after it passed it's mot on friday & there's now a grinding & ticking/clicking noise coming from around the centre bearing area .
it seems to rise when i accelerrate & fall when i let off the throttle.
the car in qeustion is a 1990 325i.
also the car has been stood for nearly 7 months which has got me thinking that the bearing had slightly seized & was now freeing up (if you know what i mean?) or it could be on it way out?
thing is it didn't make a sound when i was taking the car upto the mot station or on the way back home, it only started doing it after a good run.
any help/advise would be a great help.
steve_k
Post Mon Dec 12, 2011 9:27 am
BUMP BTTT come on folks surely some one can help??
sweep
Post Mon Dec 12, 2011 9:52 am
check the rubber on the centre bearing
steve_k
Post Mon Dec 12, 2011 10:40 am
cheers pete i'll have a look later today.
strange thing is that while i was out in the car last night i when through a few big puddles the grinding stopped & the ticking/clicking died down :? :mad:
mrLEE30
Post Mon Dec 12, 2011 10:48 am
as above you need to inspect all the componants of the prop assembly, to do this you really need to remove (or lower the exhaust) and remove the exhaust heat shield.
then you inspect
A the rubber bushing between the gearbox and prop shaft for large cracks or chunks missing - but symtoms of this are vibration not noises
B the centre bearing - inspoect the rubber bearing carrier for tears or cracks, it is unusual for the bearing itself to fail normally the rubber perishes and the bearing moves about too much, this measn vibration while driving the car.
C both U joints, check then for movement when you rock the prop on both sides of the joints, any movement visible means it has failed, you can replace the joint but it is rarely sucessful, for the price of a second hand prop buy a used unit complete...my money given your decription is this is the problem, or its the diff or the box.
steve_k
Post Mon Dec 12, 2011 10:53 am
cheers mrlee30 just praying that it's not the diff or the box as the car pulls fine through all the gears.
Post Mon Dec 12, 2011 10:56 am
WARNING !!! IF REPLACEMENT PARTS ARE NEEDED , DO NOT USE ECP SUPPLIED Q DRIVE CENTRE BEARINGS OR DOUGHNUTS !!! :(
Post Mon Dec 12, 2011 11:16 am
Ive been using Topran branded centre mounts for ages with no problems, I think GSF do them but there is a guy on ebay selling them for under a tenner winkeye
Post Mon Dec 12, 2011 12:11 pm
Genuine prop donuts are about £70 :eek:
steve_k
Post Mon Dec 12, 2011 12:27 pm
DanThe wrote:Ive been using Topran branded centre mounts for ages with no problems, I think GSF do them but there is a guy on ebay selling them for under a tenner winkeye
yeah i know who you are on about dan as i've got a few of his bit's on watch while i find out whats wrong.
steve_k
Post Mon Dec 12, 2011 12:28 pm
pacerpete wrote:WARNING !!! IF REPLACEMENT PARTS ARE NEEDED , DO NOT USE ECP SUPPLIED Q DRIVE CENTRE BEARINGS OR DOUGHNUTS !!! :(
cheers for that pete i've heard a few horror stories about them myself winkeye
steve_k
Post Mon Dec 12, 2011 4:21 pm
right been talking to a mate of mine who works at a local bmw specialist & told him what's happening & how long the car has been stood for & he said it could be a build up of crap/rust in the handbrake/rear brakes due to the car being stood so long & that when i next take the car out & the noise starts again to (gently) pull the handbrake lever up & if the pitch of the noise changes or goes completely then it's a problem witrh the handbrake.
also bear in mind that when i've gone to him or his dad (they both own/run/work at the garage) for advise then it's normalt spot on as my mate had a tech 1 sport a while back & know's e30's pretty well.
fingers crossed thats all it is.
