timing belt m20
markgE30
hiya can the belt on an e30 be 1 tooth out of timing and still run? i am asking because my engine wont rev past 5500 and it sounds lyk its being choked thts why it wont rev higher.it did before i rebuilt the head and done the timing belt.i have replaced everything i can think of.fuel pump, fuel filter, plugs, leads, distributor, fpr and the ecu yet still no joy.asked a few people and nobody seems to have a clue so this is the last thing i can think of. any help would be appreciated alot as its doing my tits right in now. cheerz Mark
markgE30
forgot to say its not an eta engine
craigieeb
Have you made sure the connectors to the T.P.S and the I.C.V are connected up the right way?
(swap them over and see if there is any change)
M50 Turbo!!!
I shall say no more
I suppose an M20 may run but crap if one tooth was out, not something i have ever tried,
surely it makes sense to first of all have a look and see if the timing marks are lined up properly ? if it is even one tooth out on the belt they won't line up
maxfield
With my experience in do cambelts, you can never get the cambelt spot on. But thats my experience though. I would always put the tooth out the the tensioner side as the belt stretches it becomes right again. IMO can't see it stopping revving.
markgE30
it runs perfect up until i hit 5500
chh137
rev limiter/
markgE30
it should limit at 6200 plus its got a chip so it should rev to 7000.is there a way of adjusting the rev limiter or is that only possible on the m10 carb engine?
kewliost
We need more info about your car? i take it is motronic if you put a chip in, what kind of chip did you put in?
markgE30
the engine is from a 325ise motoronic. its a speedtouch chip and it limited at 5500 before i fitted the chip to it aswell. the ecu has 173 at the end of the part number. when i first start the car and let it idle the first rev i give it it will rev to 7000 then after that 5500 but it sounds like the engines being strangled and stopping it from reving higher it doesnt sound like a normal car on the limiter.it says above the things i have checked and i dont know what else it could be other than the things i have listed.any help will be greatly appreciated because its starting to wind me right up now
cheerz
mrb27
afm? maybe the flap is getting stuck and wont open all the way.. just a thought
markgE30
cleaned that out with wd40 aswell still no change
