bmw e30 m52 not reving right
ante3025
Post Thu Dec 08, 2011 9:12 pm
i am in need of some help wen i rev the car up with the air flow meter plugged in the revs come down slow alot slower than thay should but we its not plugged in thay come down as thay should so wud u say that the air flow meter is dead ?
Ajsingh
Post Thu Dec 08, 2011 10:06 pm
Before asking for any sort of help. Can i kindly ask you to re Write what u have written up there so it makes sense and can be read properly.
Thank you and Welcome to the Zone!!! :)
Ajay
E30 Crazy!
craigieeb
Post Thu Dec 08, 2011 10:28 pm
Are you sure the maf is on the right way round?
ante3025
Post Thu Dec 08, 2011 10:41 pm
Ajsingh wrote:Before asking for any sort of help. Can i kindly ask you to re Write what u have written up there so it makes sense and can be read properly.
Ajay
sory i have corrected my post i wos i a bit of a rush had to go out and thanks :)
ante3025
Post Thu Dec 08, 2011 10:44 pm
craigieeb wrote:Are you sure the maf is on the right way round?
i am sure but i well make sure wen i get in to work to morrow
ante3025
Post Fri Dec 09, 2011 6:47 pm
yer the maf is the right way round
ante3025
Post Sat Dec 10, 2011 6:28 pm
Green
Post Sun Dec 11, 2011 7:48 pm
Does the car idle ok? Might be worth checking for air leaks as well.
ante3025
Post Mon Dec 12, 2011 10:42 pm
yer the car idles ok
