PROP QUESTION fly question
k20trew
Tue Dec 06, 2011 11:47 pm
if i use a 328i manual prop , do i use all of it or is it a half e30 e36? also is any other e36 prop the same length as a 328i manual? i have a e24 m30 out of a auto ! the flywheel is single mass i think ! can i use it or does it have to be a manual flywheel?
thanks guys just chasing a few final bits
E30SPORTMAD
Wed Dec 07, 2011 12:18 am
you need a manual flywheel can't use the auto back plate :cool:
leeparkes
Wed Dec 07, 2011 6:15 pm
Im sure you use the whole prop, not 100% sure though.
Bristol_Jer
Wed Dec 07, 2011 7:04 pm
With an e34 engine and manual box, you use the whole e36 328i prop, thats what I've done on mine and it fits perfectly :)
Just read again, are you using an auto gearbox on your conversion?
k20trew
Wed Dec 07, 2011 8:28 pm
thanks guys iam using a e34 manual box and e34 motor but i also have a e24 m30 motor off a auto
so i have 2 looms 2 ecu's e34 rad and e24 rad < i belive is the same dimesions as a e28
just need mounts and a prop [lee be in touch after xmas]
can i use my 318is gear linkage or do i need a m20 linkage ? 8)
Bristol_Jer
Wed Dec 07, 2011 8:32 pm
Not sure on 318 linkage, I had a 320 linkage on my car and had to swap it for a 325 linkage to make it all fit, so if a 318is linkage is the same as a 325 then I guess it will be ok!
leeparkes
Wed Dec 07, 2011 8:53 pm
Iirc 318is linkage is longer, 325i is what you need.
johnl320
Thu Dec 08, 2011 9:44 pm
k20trew wrote:thanks guys iam using a e34 manual box and e34 motor but i also have a e24 m30 motor off a auto
I am using an e24 rad, fits nicely
