Won't idle how it should... Video now added
Ajsingh
Post Tue Dec 06, 2011 6:26 pm
Car is a 1989 M20B27 and it idles around the 700 - 800 rpm mark but its not steady. It slightly surges up and down. When driving, when stopping or pulling out of gear (engaging clutch) the revs drop lower than the idle and it always feels as if the engine may stall. Quite a few times the dash lights up very dim for a split second as if its about to stall but it then picks itself up again and if standing still the slight surging starts again
Also when starting from cold, the engine runs very lumpy and misfires. As if its on 5 cyclinders. This is only under 1500-1700 rpm when cold.
Iv replaced the blue temp sensor as the last one was done with( resistance tested)
The injector harness plug is dry and lubricated so no water is in there
The idle control valve is a little suspect to me as once disconnected it and revved the car and let it idle and it made only a slight differance
The Air flow meter still has its anti tamper plug in the CO adjustment screw and the black flap looks like its never been removed. But when starting it cold, i disconnected the AFM and it started running alot better. No misfire or lumpynesss but Wouldn't rev too much as it were disconnected
I would really appreciate if someone can please help as its really frustrating and i just want it to idle how it should
Its much appreciated. Thank you
Ajay
E30 Crazy!
sunnyr83
Post Tue Dec 06, 2011 6:33 pm
Manifold gasket or any gaskets any vacume leaks??? that breather hose I got off you sorted mine out had similar issues apart from the cold start issue your having.
Still sounded nice on the uxbridge road the other day.
Ajsingh
Post Tue Dec 06, 2011 6:43 pm
Inlet manifold gaskets were replaced with bmw ones in june this year.
Breather pipe on rocker cover is in good condition
Rocket cover gasket is slightly misting oil in one corner as its a sh*t make one. I don't know it that will cause it.
Oh and thank you ;)
E30 Crazy!
sunnyr83
Post Tue Dec 06, 2011 7:18 pm
AJ what iv experienced is all I can pass on and the slightest bit of leak causes idle issues.
Sit tight, Mr Brian Moore should be around soon. :D
Post Tue Dec 06, 2011 9:33 pm
TPS checked?
Ajsingh
Post Tue Dec 06, 2011 9:37 pm
Hey brian, iv checked it & it clicks as soon as the throttle moves.
Could it be a 'duff' AFM? Or may it need CO adjustment?
But then again, iv always read never to touch that. Check everything else first but maybe its a faulty AFM
This were i need the help, end up confusing myself. Really want it sorted as its my daily driver & as u can imagine its soo frustrating
E30 Crazy!
Post Tue Dec 06, 2011 9:56 pm
If the TPS doesn't click then it's fairly certain it's duff, but a click doesn't prove it's good.
Needs checking with an ohm meter.
AFM signal isn't used at idle if everything is working properly, but I know from experience that one giving an above idle signal when it shouldn't be confuses the ECU.
Duff AFMs are more likely to give drive ability problems (positive feedback) then cause poor idle, but don't forget that the AFM assembly also contains the IAT (inlet air temp. sensor). Often overlooked.
Disconnecting the ICV on an M20 should have little effect, until the engine load changes. E.g. Switching the headlamps full on should pull the idle down a little if done with the ICV disconnected.
Ajsingh
Post Tue Dec 06, 2011 10:30 pm
It drives perfectly fine. Not an issue when driving, its faultless. Just on idle it surges up and down a few revs and on cold start its really bad.. If i start driving from a cold start, its like the engine is holding back until 1500rpm & then all a sudden, after 1500rpm it picks up n drives like normal. But go under 1500rpm when its still cold and it does the same again. Im pretty sure i have a spare AFM and throttle body with TPS attached. Should i swap one by one and see if the fault goes?
E30 Crazy!
Post Wed Dec 07, 2011 10:47 am
What are the emission readings when hot ? CO and HC figures are always a good reflection of what is going on.
Ajsingh
Post Wed Dec 07, 2011 6:25 pm
i dont have access to a gas tester :(
today on the way back from work. the issue got worse. slowing down for roundabouts, in 2nd gear, under 1500rpm, there was no power, like it was spluttering and then over 1500rpm it would pull fine but id have to put the foot to the floor. I am loading up a video on youtube, i was reserving into my slightly uphill drive away and the video shows what happens when i hit biting point and you can see and hear how much throttle has to be given to get it to move and not stall
E30 Crazy!
Post Wed Dec 07, 2011 6:28 pm
Ajsingh wrote:i dont have access to a gas tester :(
Your MOT bay at work will have one.
Ajsingh
Post Wed Dec 07, 2011 6:40 pm
our bloody MOT bays were supposed to be up and running 6 months ago, but there still not running. The tester is there but im pretty sure its not been set up or calibrated
E30 Crazy!
Ajsingh
Post Wed Dec 07, 2011 6:51 pm
E30 Crazy!
Post Wed Dec 07, 2011 6:52 pm
Dam, they are losing some serious income!
Ajsingh
Post Thu Dec 08, 2011 7:02 am
Bump..
E30 Crazy!
fowler
Boost Junkie
Post Thu Dec 08, 2011 7:29 am
Needs from what i can her and see its like it requires calibrating as the ECU "Pickup engine revs is kicking in) bit like an anti stall does it do it all the time or only when cold ??
Edit for got to add what ecu number is it running ??
EX A-Tech Workshop bitch !!!
gone but not forgotten
Ajsingh
Post Thu Dec 08, 2011 7:57 am
Alright ben, its a facelift 325i ECU with a custom 2.7 chip from Ant. It does it all te time, when in neutral stopping in traffic, they revs will bounce down as if its about to stall then back up again.
IIRC it has done this since i changed the AFM as the one on the car had been fiddled with by myself so i replaced it with one that hadn't been touched. I'll swap the AFMs around tonight n post back :)
E30 Crazy!
Ajsingh
Post Thu Dec 08, 2011 9:51 pm
I swapped the AFMs around and problem gone! It idles perfect, drives nicely and no more lag under 1500rpm. The engine was cold when starting (had been off for at least 4 hours) and there was no misfire. Went for a drive down the A5 and all was good, drives alot smoother now too
Will see how it goes in the morning with the misfire and power lag under 1500rpm
But a thank you to all who helped out....
Its very much appreciated :)
Ajay
E30 Crazy!
