No fuel to engine
bigwinn
Post Sun Dec 04, 2011 11:43 am
Hi all
Sorry I know it's a repost-
325 no fuel to engine, how do I fault find. Got pumps exposed in rear of touring to test, fuse 11 fine.
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Post Sun Dec 04, 2011 11:48 am
Link 30 to 87 on the fuel pump relay socket (orange relay with green/purple to 87) and fuel, pump should run. If it doesn't, connect a 12 volt bulb to the pump plug and check that it lights.
If it does, change pump.
bigwinn
Post Sun Dec 04, 2011 11:53 am
Sorry Brian, confused- is that relay k7?
Nor sure which relay is b7
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Dec 04, 2011 12:41 pm
If you look at your passenger inner wing there's a little plastic box. Prise off the cover and there'll be up to three relays in there. You're looking for the relay with a green-purple wire feeding pin 87.
It's often the middle relay of the three, but not necessarily.
bigwinn
Post Sun Dec 04, 2011 1:01 pm
Apologies for denseness. All found and located. When relay bridged there is no power getting to pump. Bulb over terminals not lighting. Next place to look?
bigwinn
Post Sun Dec 04, 2011 1:16 pm
No power across 87 and 30
Where next?
Behind the dash in the dist board?
BenHar
Post Sun Dec 04, 2011 1:33 pm
bigwinn wrote:No power across 87 and 30
You did have the ignition on?
Ben
bigwinn
Post Sun Dec 04, 2011 1:38 pm
Yep power was on. Checked spark too, all good
mrLEE30
Post Sun Dec 04, 2011 2:37 pm
do you have voltage between pin 30 and ground? no then inspect the red wire to the battery.
Post Sun Dec 04, 2011 3:08 pm
Ignition doesn't need to be on. With the 30 -87 link in place the pump should run all the time.
As Lee suggests, connect the bulb between 30 of the relay and ground, to check power is getting that far. (This is direct from the battery).
If that' s OK, double check that the 7.5A fuse, #11, is good, and try the bulb between the wire of the fuse (accessible on most designs of fuse) and earth.
If it lights here, and still not at the pump plug, then there's probably a (long forgotten?) immobiliser connected somewhere in the green/purple wire.
It comes down through the trunking under the fusebox into the back of the glovebox area, then goes across and down under the front edge of the speaker cover panel, before going back the LH sill, and then across the rear crossmember.
bigwinn
Post Sun Dec 04, 2011 4:24 pm
Got it. The green loop wire behind the dash was the cause, sorted that and ran first time.
Thanks all
Post Sun Dec 04, 2011 4:28 pm
Green loop wire doesn't affect the fuel pump test!
bigwinn
Post Sun Dec 04, 2011 4:31 pm
I think it was an old immobiliser set up, with a poor loop back. Completed loop and it worked!
bigwinn
Post Sun Dec 04, 2011 7:06 pm
Thanks to all that helped BTW!!!
S
