clunking noise when acelerating?
xSPARKYx
Post Sun Dec 04, 2011 12:31 am
Hi all noticed today when i acelerate i get a cluking noise coming from the back could it be the prop bearing? any help would be good :)
mrLEE30
Post Sun Dec 04, 2011 7:28 am
normally its the diff bushing, or the top mounts.
open the boot and bounce up and down, does it clunk? Yes then rear shoick top mounts to be inspected
does ti clunk when on motorway at about 50 and you put your foot down then let off?? yes then its diff bushing.
Post Sun Dec 04, 2011 9:32 am
Check the diff mounting bolts and also the nuts that hold the propshaft to the diff.
threelander
Post Sun Dec 04, 2011 9:56 am
check the donut between gear box and prop shaft
balilu91
Post Sun Dec 04, 2011 10:12 am
i have a clunking noise due to the axle mounts.. gonna fix it soon..
xSPARKYx
Post Sun Dec 04, 2011 2:07 pm
thx for the replys will go check :)
Barx325i
Post Sun Dec 04, 2011 2:52 pm
could be as simple as the rear damper lower bolt which needs nipping back up..
