Space Saver
turkeysneck
Post Sat Dec 03, 2011 9:17 pm
I'm looking to lose the spare wheel and replace it with a space saver, does anyone if the stud pattern on any other cars are the same as the old 4 stud E30 pattern.
HairyScreech
Post Sat Dec 03, 2011 10:38 pm
yes but tbh spacesavers are a waste of time, they are limited range and speed and produce some shocking handling differences in the car, i really cant understand why they are legal tbh.
a cross ply and a radial on the same axle is illegal due to the handling differences caused yet somehow a 65% width space saver is considered fine, the mind just boggles.
best bet if you want to ditch the spare is to keep a mini electric pump in the car for slow punctures and a can of tyre weld for anything more serious.
out of interest is it purely weight savings?
turkeysneck
Post Sat Dec 03, 2011 11:13 pm
I'm running aftermarket wheels and a standard spare, using the standard spare is illegal due to different size tyres on the same axle, for some reason space savers are legal in the eyes of the law. They are light, take up little room and unless you drive like a maniac or do a lap of silverstone you can't tell any difference. Carrying electric pumps and cans of glue are fine if you arrive at your car to find you've got a flat but about as much use as a bra on a dick if you have a puncture while driving. You can't actually feel a tyre is flat until the tyre sidewalls have given out and it's pretty much scrap.
Let's face it if you have a puncture of any description all you want to do is get home or to a garage which is ideal.
Weight is the enemy, it kills handling, ruins economy and kills performance.
Post Sat Dec 03, 2011 11:32 pm
I've carried one for over ten years, but never used it in anger.
I've no idea as to what it came from, as I found it lying in a scrapyard in a pile of wheels, but it is marked "Volvo".
To make it fit, I had to grind out the centre bore very slightly, and it can only be used on a rear
hub, as the rim lightly fouls the steering ball joint on the front.
Green
Post Sun Dec 04, 2011 12:57 am
A quick google finds this, ignore the numbers afterwards
BMW MINI 0 0
BMW 2002 0 0
BMW 1600 0 0
BMW 3 Series (E30) 0 0
Daewoo Espero 0 0
Daewoo Nubira 0 0
Daewoo Lanus 0 0
Daewoo Nexia 0 0
Daihatsu Gran Move 0 0
Daihatsu Sirion 0 0
Daihatsu Charade 0 0
Daihatsu Applause 0 0
Honda CRX 0 0
Honda Concerto 0 0
Honda Prelude 0 1991
Honda Accord 0 1991
Honda S800 0 0
Honda S600 0 0
Honda Civic 0 0
Kia Sephia 0 0
Kia Mentor 0 0
Kia Concord 0 0
Kia Shuma 0 0
Mazda 121 0 1995
Mazda MX5 0 0
Mazda 323 0 0
Mazda MX3 0 0
Mazda Demio 0 0
Mitsubishi Carisma 0 0
Mitsubishi Colt 1992 0
Mitsubishi Lancer 1992 0
Nissan 100NX 0 0
Nissan Almera 0 0
Nissan Micra 0 0
Nissan Sunny 0 0
Proton All 0 0
Renault Espace 0 0
Renault R21 0 0
Renault R19 0 0
Renault Laguna 0 0
Renault Clio 0 0
Renault Megane 0 0
Rover 400 0 0
Rover 200 0 0
Rover 45 0 0
Rover 25 0 0
Seat Ibiza 0 0
Seat Inca 0 0
Seat Toleda 0 0
Seat Arosa 0 0
Seat Cordoba 0 0
Skoda Felicia 0 0
Skoda Favorit 0 0
Skoda Forman 0 0
Skoda Pick-up 0 0
Subaru Justy 0 1995
Subaru Vivio 0 0
Suzuki Baleno 0 0
Toyota Yaris 0 0
Toyota Starlet 0 0
Toyota Paseo 0 0
Toyota Corolla 0 0
Toyota MR2 0 1990
Vauxhall Corsa 0 0
Vauxhall Chevetta 0 0
Vauxhall Victor FE 0 0
Vauxhall Nova 0 0
Vauxhall Calibra 0 0
Vauxhall Cavalier 0 0
Vauxhall Agila 0 0
Vauxhall Astra Mk3 0 0
Vauxhall Vectra 0 0
Vauxhall Astra Mk2 0 0
Volkswagen Polo 0 0
Volkswagen Vento 0 0
Volkswagen Passat 0 1996
Volkswagen Jetta 0 0
Volkswagen Lupo 0 0
Volkswagen Golf 0 0
Volkswagen Corrado 0 0
Volvo 360
Volvo 440
Volvo 460
Volvo 480
Volvo 340
All 4x100 although offset not sure
HairyScreech
Post Sun Dec 04, 2011 3:45 am
it will be a volvo 440/460 one brian, they are 4x100 and very close to the e30 on the center bore.
my biggest problem with them is that we may all well know they are not for extended use but the amount of cars is see driving around with them is untrue.
they also feel fine until you have a "moment", all it takes even driving sensibly is a slippy bit of road, mud etc, a little bit of aquaplaning or the need to break suddenly and your in trouble.
your forcing the vehicle into a permanent split mu situation, which produces torque vectoring, something that the abs designers had real trouble with and can very easily cause a serious accident.
has anyone tried something like a gokart or 4x4 in rwd with diff locks on, put one wheel on a slippy patch and the other on the road and pull away, again you have forced a split mu situation and you will find the vehicle screws violently to one side.
e301988325i
Post Sun Dec 04, 2011 9:51 am
Carry a can of tyre weld and RAC membership for destroyed tyre situations. Do you know anyone that's actually destroyed a tyre, apart from friend of a friend of a bloke in the pub, and I know someone who's crankshaft snapped to put it in perspective.
I said:
e30topless said:
lock the wife in there
Post Sun Dec 04, 2011 10:02 am
Anyone know anything about the rubber mix used for these things? I've had mine for ten years, and it came from a scrap yard car, so the tyre must be around 20 years old.
The rubber looks good, but I wouldn't trust an 'ordinary' tyre of that age.
gooner1
Out humping Reindeer
Post Sun Dec 04, 2011 10:19 am
Brianmoooore wrote: The rubber looks good, but I wouldn't trust an 'ordinary' tyre of that age.
Think you've answered your own question there, Brian.
Post Sun Dec 04, 2011 10:23 am
e301988325i wrote: Do you know anyone that's actually destroyed a tyre
Several, over the years. Usually as a result of clipping the inside of a corner and ripping a large tear in the sidewall. Way beyond the capabilities of an aerosol.
The last one I destroyed, about two years ago, was the front offside on an oil burning Audi A3.
The suspension geometry on these is so weird that I had absolutely no idea that I had a flat tyre - not the slightest feel from the steering. All I could feel was a severs loss of power, and after about a mile I found somewhere to pull in, expecting to find a split turbo pipe or suchlike. Couldn't believe it when I got out and saw the tyre.
HairyScreech
Post Sun Dec 04, 2011 11:24 am
iirc its recomended to change tyres after 4-5 years even if they have had no use. simply as the rubber degraded and hardens.
Post Sun Dec 04, 2011 11:32 am
HairyScreech wrote:iirc its recomended to change tyres after 4-5 years even if they have had no use. simply as the rubber degraded and hardens.
I know this. (Over six years is illegal in Germany), but since spacesavers are designed to (hopefully)remain stowed away for the whole of the cars life (my Volvo one still has the moulding marks on the tread), I wondered if they were made from a 'long life' rubber.
gooner1
Post Sun Dec 04, 2011 12:25 pm
Brian, according to this excerpt from an AA site the Spacesaver Tyres are often made from a softer
compound than normal tyres. Being stowed, away from the elements, in a Boot presumably
would increase the life expectancy somewhat.
Space-saver wheels are designed for temporary use to enable the vehicle to be driven to a place of repair. There is no maximum distance but due to the speed restriction, limited tread depth (only 3mm from new) and the fact that the tyre compound is often softer to simulate the traction capabilities of a wider tyre, the distance covered before repair should not be excessive.
Morat
Post Sun Dec 04, 2011 12:52 pm
I ran over a vine tie a few years back. It left a two inch gash through the tread.
e301988325i
Post Sun Dec 04, 2011 1:21 pm
It's UV light that perishes the rubber of tyres, so they will last much much longer tucked away in the boot.
I said:
HairyScreech
Post Mon Dec 05, 2011 12:19 am
i thought it was up to 50 miles.
