sagging rear
jimbob29
Post Thu Dec 01, 2011 10:55 am
ive noticed lately that the rear of my saloon is lower than usual?cars been lowered 35mm front and rear.shocks are standard but showing ther age and springs are 3 months old.thers no knocking from rear and feels normall.could worn drop links or subfram bushes cause slight sagging or is it an illusion because the rear arches are lower than the front :mad:
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Dec 01, 2011 12:03 pm
Measure it side to side rather than front to back. It would be odd for both sides of the rear suspension to develop a fault at the same time.
Also, how are your top mounts? There's been lots of stories recently about them being knackered because people forget to fit the support plate, so they tear within a week.
TouringMatt
Post Fri Dec 02, 2011 11:35 pm
Springs do settle in, mine looked spot on for a few weeks then slowly settled.
Could be worn subframe bushes, if everything is good then you can put some thicker spring pads in to bring it back up a touch, but i'd check your subframe bushes first.
kam-325i
Post Sat Dec 03, 2011 9:42 am
Knackerd sub frame bushes can drop the rear end by about 10mm
HairyScreech
Post Sat Dec 03, 2011 2:29 pm
^ this, and also if you park on a slope the twin cable handbrake with no equaliser can pull one brake more than the other, leading to one doing all the work and sagging or lifting that side.
