Hi there,
I am a new owner of a 320i cabriolet. When the roof is down it looks as if there should be a plastic panel at the back of the interior rear panel to cover a hole on each side where the steel roof mechanism sits. Hole is approx 2 or 3 inches square. It is immediately in front of the horseshoe on each side, but in the interior panel NOT the horseshoe. I have looked in the on-line catalogue but can't see if it exists. There do seem to be the remnants of some clips there, so I am guessing they should be there. I am wondering if they clip in only when the roof is stowed away? Any help on identifying them would be gratefully received!!
Many thanks,
MarkS100
Convertible - plastic trim panel question
andyp
- True Old Skooler
hi and welcome to the zone,
yes you are right there should be a square-ish plastic flap each side with a spring lid
Gert_8
Hello. Welcome. If they are missing you'll probably be able to get replacements from somone breaking a cab on here. easy to fit. Car looks annoying without them, doesn't it?!
MarkS100
Great - many thanks, I can understand why a spring lid would work here. Now I just have to get hold of a couple!
andyp
- True Old Skooler
i dont think they are much to buy new from the dealers.
