steering colum
paddster
Post Thu Dec 01, 2011 10:45 am
Hi The steering wheel on my e30 has like free play and someone has told me that its caused be a worn steering column and it needs a new column. How easy is it to replace as i have another colum that i know is good so was wondering whats involved in changing it?
Duke137
Post Thu Dec 01, 2011 11:04 am
More than likely it is the rubber guibo in the lower coupling and not the steering column. These are a bit perished after 20 odd years.
You could replace the whole coupling or replace the rubber guibo for an alloy one.
Below is a link for the quick rack conversion but the alloy guibo is shown at the bottom.
http://www.e30zone.net/e30zonewiki/inde ... onversions
It's not a difficult job to replace the whole coupling, just a bit fiddly due to access. I doubt very much it will be the actual steering column
Post Thu Dec 01, 2011 8:59 pm
http://www.e30zone.net/modules.php?name ... 38#2300438
You need #3 and four of the special bolts #6.
The original guibo is held with rivets, which need to be ground off, and the new is fitted with the special shouldered bolts, plus washers and nyloc nuts.
The coupling shaft can be removed by removing the pinch bolts in the clamps and sliding it up and down to remove it, but its easiest to slacken the LH steering rack bolt and completely remove the RH bolt, so that the RH end of the rack can move forwards.
