Central locking failed - how to open petrol cap?
Bump
Post Tue Nov 29, 2011 1:17 pm
hi there
My central locking has failed on my Touring.
I can unlock the drivers door with the key but no other doors unlock.
The key won't lock anything either. So to lock the car I have to reach through from the rear passenger door to push down the drivers door locking pin. Then can shut the passenger door.
Right now I can't afford to get it fixed in a garage and also don't have time to fix it myself.
Trouble is the petrol cap won't unlock either.
Can anyone tell me if there's a way to unlock the petrol cap please as it's on empty now?
Many thanks.
How hard is it to fix it myself?
cheers, Simon
You don't win friends with salad.
greg124
Post Tue Nov 29, 2011 1:24 pm
Not sure about a Touring, but on a saloon you pull back the carpet, and can operate the solenoid manually.
Also, check fuse 27
Hope this helps
Schadenfreude - the German's haven't got a word for that.
jimbob29
Post Tue Nov 29, 2011 5:52 pm
try unlocking it from the boot?
threelander
Post Tue Nov 29, 2011 5:58 pm
try turning the key twice
Bump
Post Tue Nov 29, 2011 6:45 pm
Key turning does not work.
Will give it a go from the boot and check fuses.
threelander
Post Tue Nov 29, 2011 6:49 pm
do you have the key fob for the car
Post Tue Nov 29, 2011 9:19 pm
Couldn't be easier releasing the fuel cover lock on a touring.
Open the RH door in the luggage space, and you can hook the lock plunger back through a round hole in the liner at the side of the locker, or you can remove the two quarter turn fasteners at the top of the liner, and bend it out enough to get hour hand to the locking motor.
Boot lock should undo with the key, whether the system is deadlocked or not.
Remove the cover over the speaker in the driver's footwell, remove the speaker, and do the "red/black wire" mod.
mrb27
Post Tue Nov 29, 2011 9:46 pm
when mine went i used a screwdriver between the petrol flap edge and the body work edge.. i had like a 2mm gap where i could see the locking rod, being very careful not to damage the paintwork u can work the rod back with a flathead screwdriver.. how i did mine anyway ^^
Post Tue Nov 29, 2011 9:57 pm
mrb27 wrote:when mine went i used a screwdriver between the petrol flap edge and the body work edge.. i had like a 2mm gap where i could see the locking rod, being very careful not to damage the paintwork u can work the rod back with a flathead screwdriver.. how i did mine anyway ^^
BMW supply both the facility and the instructions for releasing the lock from inside, so why would you risk damage to the mech. and paint by doing it this way??
Bump
Post Wed Nov 30, 2011 1:57 pm
Thanks Brian, great to know that!
I've seen a few links to the red/black mod. Is there a definitive article I should read?
Thanks again.
Bump
Post Sun Dec 04, 2011 4:02 pm
Thanks to all for the replies, the red/black wire mod fixed it:
http://www.e30zone.net/e30zonewiki/inde ... g_problems
Great this place :D
