Hi peeps, I'm thinking of getting some original e30 front spotlights for my 1989 e30 316i 3door coupe. I'm just wondering if theres anyone on here who would fit them for me.
Any help is much appreciated.
Ry.
Fitting original e30 foglights?????
stokiedundee
gooner1
- Out humping Reindeer
The wiring is probably already installed on your car.
Least it was on my 316i Touring.
The wiring will be there. You need to fit the lights themselves, which will require the correct square plastic plugs for the front panel, a relay, identical to K4, in the K8 position, fuses 29 and 30, the twin button foglight switch, and a tell tale light in the instrument cluster.
Simple DIY job.
Simple DIY job.
