*URGENT!* Wiper Motor!
Bigbenstrikes
Hey guys, bit of an urgent one! The weather in the north west of scotland is a bit horrific to say the least! My wiper motor packed in within 40 minutes of my 3 hour journey home! It goes up fine but on the returning swipe it doesnt move from 12 oclock and the motor makes a loud noise! We had to get home so we found out that when i give it a push it then returns to its resting position. So currently i have a shoe lace hanging out the window attached to the wiper andmy friend gave it a tug when it got stuck! It was pretty funny but its not safe! Is there anything i can do to fix this or is it new motor job? Cheers guys!
oomz1975
Wiki won't help much, because this is a "one off" fault.
Sounds like the plastic gear wheel may have stripped a tooth or two, or the output shaft bush is so badly worn that the gear can move away from the worm.
Bigbenstrikes
I was thinking more towards that brian as in my E46 the rear wiper motor did the same, the plastic cog stripped its teeth! So would you recommend a new motor all together?
You certainly need a replacement motor - spares aren't available.
Check any second hand one for wear to the output shaft bearing bush. This is common on RH drive E30s, and is probably down to a bit of a design fault - putting the upwards facing output shaft directly under a scuttle grille.
