Hi
i will be removing my engine to get another in but i was thinking what would be the best choice:
=> loosen driveshaft and engine mounts and box mounts and all the rest and pull box and engine out at same time
=> Get the box of first then pull out the engine seperate (I don't have a bridge to put the car on or a pit, so it would be hard to get the box out underneath)
what would be the best option for me?
I'd rather pull them out together but is this possible without damaging anything or any problems?
removing engine with box at same time
taking them out together is far less messing about than trying to unbolt the box from the engine in situ.
tip, when you are ready to take it all out, get the arse end of the car as high in the air as possible
Kedge
What engine is it? When swapping M42s i've always found it easier just leaving the box in, suspect all 4 pots would be the same. If it's a 6cyl then yes, all out in one.
One hit FTW
Pikey style on the road in front of the house
