1.1 TO 1.3 Motronic on a 1986 325i
gooner1
Out humping Reindeer
Post Fri Nov 25, 2011 9:21 pm
While still in the midst of my 2.8 build, I have decided
that while the old lump is still sat in the car now would be a good time to do the Engine management upgrade.
Luckily enough for me,Sanchez today posted a link, in a totally
unrelated thread, which show s me where this part should be located.
http://bmwfans.info/parts/catalog/E30/T ... pper_part/
If i've got this right, this part Image
should be located somewhere down around here.
http://bmwfans.info/parts/catalog/E30/T ... on_damper/
Am i correct in thinking that i only need to replace part No 2,
and not part No1 itself?
Will be taking copious amounts of photos, and needing copious amounts of help, but hopefully when finished this can all be
cleaned up and used as a guide to others.
TIA.
m_jermyn
Post Sat Nov 26, 2011 2:54 am
If you are converting from motronic 1.1 - 1.3 there is a lot more to it then just one part.
The part in the first pic is the crank position sensor and it sits at the bottom of the engine just near where the A/C compressor is.... If looking from the front of the car its bottom left.
I have no idea what the part is in the second pic you posted.. It looks like a crank position sensor however the plug is wrong... The plug is a 3 wire plug not that multi plug thing on your 2nd pic.
You need part # 8 in the link provided....
m_jermyn
Post Sat Nov 26, 2011 2:57 am
This is what you need..
Facelift loom with injector loom
Facelift ECU
Facelift AFM
Facelift oil level sensor
No 6 lead with cylinder ID sensor
ICV
Crank sensor & bracket with 10mm bolt
Toothed timing wheel
Diagnostic plug bracket
Bracket that runs beneath the throttle body that holds the injector loom plug c191
High impedance injectors
Thats the list, apparently your old injectors will work.... That is everything I replaced on mine
Kedge
Post Sat Nov 26, 2011 3:15 am
No idea what that second thing is Rob, had nothing like that on mine.
I never changed my injectors though, car runs but hasn't been driven so i hope they are ok as i've had them refurbed by Injectortune.
Want me to get you some pics of mine in the next few days? It's any easy enough job, mainly just a case of direct swaps. I can e-mail you a guide for the wiring you need to do, only 2 or 3 wires.
Instagram - Kedge85
m_jermyn
Post Sat Nov 26, 2011 3:37 am
I really should do that conversion guide :?
If you can hold off for a week I will write a 1.1 - 1.3 conversion guide complete with pics...
The only hard part is wring up your tacho :D
Kedge
Post Sat Nov 26, 2011 3:43 am
I was meant to do a guide as well but did my normal routine of putting everything together and forgetting to take any pics.
Even the wiring isn't hard so long as you're not colour blind :cool:
Instagram - Kedge85
m_jermyn
Post Sat Nov 26, 2011 3:49 am
Kedge,
How about I write it and send it to you for input? We can do it together :D
Kedge
Post Sat Nov 26, 2011 3:59 am
Yea sure, i can try and add in the wiring info i have somehow :cool:
Instagram - Kedge85
gooner1
Post Sat Nov 26, 2011 7:16 am
Many thanks Mike, Dave.
Mike,
" If you are converting from motronic 1.1 - 1.3 there is a lot more to it then just one part.'
give me some credit mate. "Will be taking copious amounts of photos, and needing copious amounts of help,"
Even I could change one part ,without needing to employ the word "copious" :)
I have all the below, except the Facelift AFM.
" This is what you need.."
Facelift ECU
Facelift AFM
ICV
Will be using the injectors from my preface lift, for now at least. :thumb:
BMWE30325
Post Sat Nov 26, 2011 4:45 pm
How to know if am running 1.1 or 1.3?
darren_mk
Post Sat Nov 26, 2011 4:51 pm
BMWE30325 wrote:How to know if am running 1.1 or 1.3?
1.1 = 2 rows of pins on the ecu
1.3 = 3 rows of pins on the ecu
Post Sat Nov 26, 2011 4:55 pm
1.1 was used on 325i's up to september '87.
Kedge
Post Sat Nov 26, 2011 4:56 pm
I'm told you do need the facelift AFM, mine runs on the old one but don't know how it'd drive.
Instagram - Kedge85
BMWE30325
Post Sat Nov 26, 2011 5:00 pm
Whats the diffrence?
Post Sat Nov 26, 2011 5:50 pm
Kedge wrote:I'm told you do need the facelift AFM, mine runs on the old one but don't know how it'd drive.
Not true!
Same part numbers for both.
I converted an '85 325i to motronic 1.3 and retained the original AFM, it runs perfect and the cars done over 10k since.
It belongs to SteSE on here.
gooner1
Post Sun Nov 27, 2011 9:30 am
Thanks Barry.
There you go, bonnet not even lifted and already one myth appears to
have been disproved.
Post Sun Nov 27, 2011 10:24 am
No need change the injectors either.
gooner1
Post Sun Nov 27, 2011 10:55 am
How about the ICV :?:
May have this wrong but i;m pretty sure someone on here has kept
the earlier one on their conversion.
Post Sun Nov 27, 2011 10:59 am
AFAIK, the only difference between 325i ICV's are if they are L or T shaped and there for need the matching throttle intake boot.
I'm pretty sure i retained the original on SteSE's conversion.
gooner1
Post Sun Nov 27, 2011 11:03 am
Cheers Barry, i like the way this list is shortening.
retroboyo
Post Sun Nov 27, 2011 11:23 am
Can I use all the bits from a m20 320, except the ECU. Would be handy as I have a 320.
gooner1
Post Sun Nov 27, 2011 11:32 am
retroboyo wrote:Can I use all the bits from a m20 320, except the ECU. Would be handy as I have a 320.
Hope so, Boyo, as that's exactly the model my bits and loom
came from.
Believe you can also gave the 320 ECU chipped so it's
possible to use.
m_jermyn
Post Sun Nov 27, 2011 11:43 am
To clear things up a little....
My car would refuse to run on the pre facelift AFM, swapped to a facelift one and bang she started...
From memory there is a difference between the ICVs and I think its the pre facelift had a 2 prong connector and the facelift had a 3 prong connector....
Absolutely you can... Thats exactly what I have used.
Tomorrow I will clear all this up and check out all my old parts ect ect.. Go through all the pics and makes sure what I wrote above about the ICV is fact... Give me 24 hours. :D
Post Sun Nov 27, 2011 11:54 am
ICV is the same depending on T or L shaped,
AFM is the same facelift or pre-face unless you use a very early pre C101 plug (metal Air filter housing )
differences on the loom are..
Throttle body plug (tps) is different on auto's compared with manual
early starter motors only have 3 wires compared with 4 on later models fitted with 1.3
oil pressure switch is a single spade connector on early cars,
very early cars have this type of plug instead of the C101 used on 1986 onwards,
here's the 1986 onwards type of C101
gooner1
Post Sun Nov 27, 2011 11:59 am
[quote="e30topless"
Image[/quote]
Yep, that's the one i've got ,Steve. :thumb:
Post Sun Nov 27, 2011 12:01 pm
thats a good start Rob, :D
I did an Early car 1985 to 1.3 last year and changed the entire car loom to have that plug :eek:
gooner1
Post Sun Nov 27, 2011 12:03 pm
e30topless wrote:thats a good start Rob, :D
Oh dear. :eek:
gooner1
Post Sun Nov 27, 2011 12:08 pm
e30topless wrote: early starter motors only have 3 wires compared with 4 on later models fitted with 1.3
...... and the solution to that is?
m_jermyn
Post Sun Nov 27, 2011 12:29 pm
Gooner you just need the engine bay loom mate.... its all easy buddy dont stress... :D
Yours is the same as mine and the one topless pictured..
I have heaps and heaps of pics of my conversion which is exactly the same as yours
gooner1
Post Sun Nov 27, 2011 12:58 pm
m_jermyn wrote:Gooner you just need the engine bay loom mate.... its all easy buddy dont stress... :D
No worries mate. :) :thumb:
Kedge
Post Sun Nov 27, 2011 6:17 pm
:wave:
Saves not buying an inlet boot as well :D
Instagram - Kedge85
Post Sun Nov 27, 2011 7:23 pm
m_jermyn wrote:To clear things up a little....
Which E30 model did your car start out as? If it was a 320i or 323i then it would have had Bosch LE jetronic not Bosch Motronic 1.1 hence why you engine would not run on the original AFM as it is a different part.
e30topless wrote:very early cars have this type of plug instead of the C101 used on 1986 onwards,
September '85 build date onward uses the C101, all 325i's have a C101.
I'm guessing the car you did was that Hartge H23 which was a 323i base car with LE jetronic hence the lack of C101?
To clear things up a little for the OP with a 325i with Bosch Motronic 1.1 there is no need to change the AFM, Injectors, ICV, body loom etc.
m_jermyn
Post Sun Nov 27, 2011 11:45 pm
Its a 86 325e with distributer on the front of the head not LE jetronic.
Here are some real clear pics of the original engine with original wiring.
Notice the very small diagnostic plug socket near the dipstick.. ANd the C101 has only a handful of wires in it just like topless has pictured in his.
m_jermyn
Post Sun Nov 27, 2011 11:47 pm
The old C101 opened up...
Post Mon Nov 28, 2011 12:00 am
That will explain it then, the eta engine has a different AFM to the 325i.
I think if there is going to be a write up for the wiki then all these differences need to be covered depending on the car you are starting with.
Obviously a 325i is the easiest to convert.
