cabin temp sensor - heater vlave
liam012
Post Sat Nov 05, 2005 2:07 pm
Hi - when ever i turn on the heat from any setting but the coldest i can hear the heater valve knocking (opening and closing quite quick) does any one know of a reason for this - i have whatever heat i want but the valve just opens and shuts causing that annoying sound.
at the moment i am going to check the cabin temp sensor, but i cant find it?! does anyone know where it is?
thanks
liam
ian332isport
Post Sat Nov 05, 2005 3:02 pm
liam012 wrote:Hi - when ever i turn on the heat from any setting but the coldest i can hear the heater valve knocking (opening and closing quite quick) does any one know of a reason for this - i have whatever heat i want but the valve just opens and shuts causing that annoying sound.
thanks
liam
Liam,
That sounds like you have the heater hoses swapped over at the bulkhead. Basically the water is flowing the wrong way through the valve.
It's caused by the flow of water lifting the valve off it's seat. Once it's lifted, the pressure is reduced, and the valve clonks closed again.
Ian.
Post Sat Nov 05, 2005 5:09 pm
Yes, almost certainly some numpty has managed to cross over the two heater hoses at some time in the past.
The cabin temperature sensor should be behind the little projecting grill top left of the heater knob, but you won't find it, as I'm fairly sure BMW never got around to fitting it to any E30.
liam012
Post Wed Nov 09, 2005 5:11 pm
so how does your cabin know if its 27 degrees or not?!!
thanks a million though - that knocking has been driving me demented - i reckon you are right coz the knocking increases with acceleration which would be i presume the coolant speeding up due to water pump,
will let u know
thanks
kam-325i
Post Wed Nov 09, 2005 5:17 pm
liam012 wrote:so how does your cabin know if its 27 degrees or not?!!
When you have to open the windows.......
liam012
Post Mon Nov 14, 2005 11:43 am
you were right!!
problem solved -
a big thanks
regards
liam
tourer-dan
Post Mon Nov 14, 2005 1:42 pm
There is a cabin temp sensor up in the dash somewhere, I think to the left hand side of the ducting around the matrix.
