Ok so since i got my k reg 316 touring a couple of months ago it has had a very annoying missfire which only seems to happen at high revs, usualy around 1-2k before the redline which then once you change gear will keep missfiring until you back off the throttle for 10-15 seconds then put your foot down again and it will be fine.
I know it is definetly a missfire as it is a juddering sort of noise and it loses power, only thing that has been changed is the plugs when i cracked the sump.
Any help on this would be greatly appreciated!
Craig[/url]
316 missfire at high revs
Rtaylor2208
Were the plugs gapped correctly when fitted?
Grrrmachine
- E30 Zone Wiki / Team Member
99% worn cam. We had a thread recently about a guy with almost the exact same symptoms; the cam was mentioned and he said "no, it's definitely a misfire" and went on to spend a month and god knows how much money swapping out every other component in the engine before coming back to the cam...
Have a look at this thread, and the one it links to:
http://www.e30zone.net/modules.php?name ... c&t=208972
