Replacing Rocker Cover Gasket
Rtaylor2208
Post Wed Nov 23, 2011 9:29 pm
Probably a stupid question but is removing the cam cover as easy as removing the mounting bracket for the manifold then the 8 or so nuts holding the cover on?
Got a small oil leak from the cover so think the gasket needs replacing.
Ajsingh
Post Wed Nov 23, 2011 9:35 pm
Its as easy as that mate
E30 Crazy!
CHR1S1990
i'm assuming m20 engine, then it sure is (plus the breather pipe)
Post Wed Nov 23, 2011 9:39 pm
Replace the D shaped rubber bungs in line with the rocker shafts as well, and make sure the little rocker shaft locating plate at the front of the head is in place properly when you replace the cover.
Rtaylor2208
Post Wed Nov 23, 2011 9:56 pm
Thanks All, sorry yes M20 2.5,
Brian once I order up the gasket and the bungs I'll probably come back to you about the above for help.
xavier
Post Fri Nov 25, 2011 2:19 am
Its v. easy. give the rocker cover a good clean and repaint while it is off. I did and it neatened up the engine bay no end
Rtaylor2208
Post Fri Nov 25, 2011 4:10 pm
Brian, can you help identify the parts for this please. Had a look on realoem but can't find them. Going to order up the gasket and these from cotswolds on Monday
xavier, it will be getting painted also, would like to do the manifold as well but not sure I'm brave \ skilled enough to take it off and put it all back together correctly yet.
Post Fri Nov 25, 2011 6:31 pm
#13 on here: http://bmwfans.info/parts/catalog/E30/T ... cam_shaft/
#6 is the locking plate I referred to.
Rtaylor2208
Post Fri Nov 25, 2011 8:00 pm
Thanks Brian
CHR1S1990
Post Fri Nov 25, 2011 11:09 pm
Inlet manifold is very simple too. Im sure there's a guide somewhere but if not, I can get one written.
