Where does this hose go?
sheebie
Post Wed Nov 23, 2011 3:00 pm
Anyone got any ideas where this hose goes?
I just had my injectors cleaned and replaced some fuel pipe and noticed this hanging down.
It follows the fuel lines, but im not sure where it is meant to go.
The car is a 318 with a 325 conversion. I have not had a chance to jack the car up and look underneath yet.
TPS
Post Wed Nov 23, 2011 3:11 pm
Is that the Fuel tank Breather pipe, goes into the bottom of the suspension turrent?
sheebie
Post Wed Nov 23, 2011 3:14 pm
could very well be, i just found it hanging. Does it connect to something or clip into the bodywork somewhere?
Jim320i
E30 Zone News / COTM Team
Post Wed Nov 23, 2011 3:15 pm
Wheres the other end come from? :?:
sheebie
Post Wed Nov 23, 2011 3:22 pm
It disappears under the car, same place the fuel lines come from. Possibly is the Fuel tank breather pipe.
I didnt get time before work today to jack the car up and have a proper look
Rtaylor2208
Post Wed Nov 23, 2011 3:38 pm
Definetly the breather pipe. There should be a clip near the passenger side turret to hold it in place.
sheebie
Post Thu Nov 24, 2011 11:31 am
Rtaylor2208 wrote:Definetly the breather pipe. There should be a clip near the passenger side turret to hold it in place.
Okay thanks, a little upset as i though i finally found the airleak, oh well have to keep checking
Rtaylor2208
Post Thu Nov 24, 2011 12:04 pm
On the Throttle body there is a blanked off pipe which is used for some carbon canistor thing that I'm pretty suire UK cars dont have. This tends to go and causes an air leak.
Its abvious with the TB off the maifold, but from memory its on the underside on the fan side.
Also someone else had recommended that the breather pipe that goes to the brake servo and the pipe that goes to the Idle Control Valve on the TB are good candidates for air leak as they dont have a tight fit into the TB. try some carb cleaner around those parts and if it revs the engine up youv'e got your leak.
sheebie
Post Thu Nov 24, 2011 5:46 pm
Done all those apart from the bit below the tb i know what u mean. Thats next and if its not that then im going to live with it throught the winter atleast..
