going to view an 1985 316 e30
gazwhittle
Post Thu Nov 24, 2011 10:17 am
Hi guys , first post !
ive been looking for an e30 for a while now and the perfect car has just popped up.
i can only get insured on a 316 pre 1989 on a classic policy for some reason.
so yes the car she has 64k miles with history and 3 owners from new !
the guy says "surface rust" has started around the bottom of the doors and on rear arches which he has treated and primed.
my question is what are the prime areas for rot on these ?
cheers guys !!! sorry if im in the wrong section.
peace :cool:
Curr946
Post Thu Nov 24, 2011 10:20 am
where abouts are you? maybe a local member could go with you for a look?
If your wife must learn to drive, don't stand in her way!
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Nov 24, 2011 10:47 am
gazwhittle
Post Thu Nov 24, 2011 10:50 am
im in wigan (manchester) and cheers grrrmachine.
skipunda
Post Thu Nov 24, 2011 10:52 am
Primer left too long will absorb moisture and effectively rusts beneath it. Perhaps not all primers, but those that I've seen, do.
edited out, Rich beat me to it - again!
Chris
gazwhittle
Post Thu Nov 24, 2011 11:02 am
If its just surface rust then i can deal with it and get it resprayed but cant deal with any major rust problems.
Grrrmachine
Post Thu Nov 24, 2011 11:11 am
gazwhittle wrote:If its just surface rust then i can deal with it and get it resprayed but cant deal with any major rust problems.
Have to say it; don't buy an E30 then. It's not a matter of "if there's rust", but "WHERE'S the rust".
A big hole in the floorpan will be cheaper to fix than a small bubble in the arch; it's not the size of the rust that matters but where it is, and will it need repainting afterwards; THAT'S the cost.
gazwhittle
Post Thu Nov 24, 2011 11:16 am
repainting aint a problem dude mates rates in a body shop ive been using for years.
sills being patched ect aint a problem.
i mean i can afford to patch a few places. but to have both sills , arches , floor , scuttle ect welded is a no no.
Grrrmachine
Post Thu Nov 24, 2011 11:22 am
ok :D In that case, I think you'll be fine. Just look for the rust in the places highlighted, take a camera with you, and post them up here if you're unsure of how serious it is.
It's the hidden places you need to investigate, like all the corners of the boot and the front corners of the floorpan. Being a chromey, I doubt it'll have a body kit on it; if it does, be suspicious.
If the bumpers are rusty, you're in for a shock though; replacements are expensive!
gazwhittle
Post Thu Nov 24, 2011 11:25 am
cool cheers dude ! as said above if anyone wants to come with me to look at it ill be very grateful
