bmw e30 m52
ante3025
this is my fust m52 swop. started the car for the fust time to day and it started fust time but number 15 to 15 on the pug keeps smoking and getig red hot eny ideas on y it is doing this ?
leeparkes
Fust? Are you from the black country?
If you mean pin 15 is smoking at the main 20 pin plug ffs disconect it now, its shorting out!
ante3025
i have disconect it. but y is it shorting out?
I suspect because you have wired it up wrong
15 is the black/green unloader relay wire, and shouldn't 'smoke' whatever you connect it to - live, earth, or anything in between.
ante3025
the wireing i had don wos right so i pulled out the wireing out under the dash and the black/green wire wos burnt out so i folled it back and it had rub thow and maed it earth out so i cut out the burnt out wire and put new wireing it it mint now the wires are not geting hot and not smokeing. thanks for all your help ad all your advice
